Redoing my backyard, need suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-15-2012, 03:19 PM - Thread Starter
Stryker412's Avatar
Liked: 26
We are having our backyard completely leveled and new top soil put on. When that's all done I thought it would be a nice idea to do some backyard movies. I'm looking for suggestions on equipment,
- a 720p projector
- a way to do the sound wirelessly
My brother just installed the sonos amp at his house for music and it works great. I will have. 2.1 receiver in my house hooked to speakers that are connected outdoors to the house. I want to project on the side of the house and I thought doing it from my iPad using Plex to access my movies would be the best way to do it. I can do 720 from the iPad easily over wireless. My only concern is how to split the audio?
Stryker412 is offline
post #2 of 10 Old 07-16-2012, 07:34 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
If it were me and I was having my entire backyard re-done, I would go ahead and bury conduit for a full 5.1 audio setup and make the conduit big enough to run HDMI. I'd run power out there in a separate conduit, too. Then you can run/play whatever you want.
There are also several ways to make a screen so that you're not just using the side of your house.
Check out backyardtheater.com for LOTS of great ideas and help.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 10 Old 07-16-2012, 06:13 PM - Thread Starter
Stryker412's Avatar
Liked: 26
Well we're going to spend a LOT of money on redoing our yard that this theater idea is a last minute thing and is not really in the budget. I wanted to just get a projector and run an extension cord out to set it up when it's needed. The only issue I'm trying to figure out is how to wirelessly send the audio to the receiver inside.
post #4 of 10 Old 08-28-2012, 04:54 AM - Thread Starter
Stryker412's Avatar
Liked: 26
Can anyone suggest a good sub $500 outdoor 720p projector? I don't mind if it's used either.
post #5 of 10 Old 09-01-2012, 04:05 PM - Thread Starter
Stryker412's Avatar
Liked: 26
My brother can get me an Epson 710HD for under $500 as an open box at BB. How would this projector fair outdoors? Is 2800 Lumens enough?
post #6 of 10 Old 09-02-2012, 07:13 AM
Impetus's Avatar
Quoted: 12 Post(s)
Many users on http://backyardtheater.com/forums/index.php?board=8.0 use the previous version of that PJ (705HD) to much success.
I bought one to use for an outdoor setup as well. But rain/heat here in Louisiana prevents my 1st testing as of yet.
A couple days this coming week the forecasts are 0% rain. You know what that means...
Impetus is offline
post #7 of 10 Old 09-02-2012, 07:40 AM - Thread Starter
Stryker412's Avatar
Liked: 26
I guess I just have to figure out if $499 is worth it, if I'm only using it a few times a year.
post #8 of 10 Old 09-11-2012, 08:35 AM
PMR
PMR's Avatar
Hello I use a 705HD at it works great. Getting a 710HD for 500 sounds like a good deal unless
you can find a used one on Ebay for cheaper.
PMR is offline
post #9 of 10 Old 09-15-2012, 08:37 PM
rhilyard's Avatar
I use a FM transmitter that I bought from Ramsey. Just hook it to the dvd player or any audio source and turn any radio to that fm station. Can also ask you guest to bring boom boxes so everyone can hear the sound.
Hope that helps.
rhilyard is offline
post #10 of 10 Old 03-30-2013, 12:30 PM - Thread Starter
Stryker412's Avatar
Liked: 26
Hey all I want to renew this thread. We now have our new fence up and will be seeding the backyard again soon. We'll be hooking up outdoor speakers in the next two weeks for my son's 2nd birthday. I thought it would be cool to show a movie later that night for those that were still around. Have any good deals on projectors popped up in the last month or so? Keep in mind I will only be using it a few times a year and outdoors. Also the source for the movies will be an iPad Gen 2 so 720p is the max resolution it'll do.
Reply Outdoor Theaters
