18' awning - AVS Forum | Home Theater Discussions And Reviews
Old 01-22-2013, 05:36 PM - Thread Starter
woody1313's Avatar
I have a 18' motorized awning i want to use for my BYT up grade this spring. does any one have any suggestions on what screen material i can use?
Once rolled up it would be protected from the elements but may get hot in the summer time while in its enclosure. Would BOC take the heat? I have seen some tarps form mytarp.com but trying to stay seamless.
Thanks for any help you can offer.
Woody
woody1313 is offline
Old 01-22-2013, 08:02 PM
Cool Face's Avatar
do you plan on using the full 18' width?
BOC can take the heat but its the bugs and other "crap" that can easily stain the material. i have a 16' wide BOC screen so i know this. i dont roll it up though. in bad weather, i fold it down and store it.
have you considered a billboard tarp screen? they're a bit cheaper than a giant BOC screen and can take some wild abuse. easy to clean, but a challenge to make ready for BYT. billboard tarp is also slightly transparent. you cant rear-project though, but you can see the image on the opposite side.
another material is Dazian Trapeze fabric. just about the same price as a BOC screen depending on the size you need covered.. a certain style is made for front and/or rear projection. and if it gets dirty then simply throw it in the washer (hang dry only)
Cool Face is offline
Old 01-23-2013, 06:17 PM - Thread Starter
woody1313's Avatar
Cool Face,
thank you for the info. I plan on using at least 16'x9' or maybe 10' x18'. I found a web site for billboard trap pretty good on price. have you seen a projection movie on one?
Old 01-23-2013, 08:38 PM
Cool Face's Avatar
Yes. 2 fellow BYT enthusiasts live nearby me and both have billboard tarps. Once BYT starts up again I'll let them know about your inquiries.
Old 09-02-2013, 12:55 PM - Thread Starter
woody1313's Avatar
I should have post my upgrade here instead linked below
http://www.avsforum.com/t/1488801/screen-upgrade
