Outdoor USB projector recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-10-2013, 11:02 AM - Thread Starter
Soriano01's Avatar
Hi everyone,
I'm looking for an LED outdoor projector with USB capabilities to change the projected image often. Basically, the image will be projected onto a concrete wall showing still images. Any recommendations? I'm looking for something not overly expensive.
Thanks for you help!!
Soriano01 is offline
post #2 of 4 Old 10-18-2013, 07:57 PM
xnum27's Avatar
HI:
I AM LOOKING FOR THE SAME KIND OF PROJECTOR.. HAVE YOU FOUND ANYTHING?
xnum27 is offline
post #3 of 4 Old 02-22-2014, 12:43 PM
The Tim Channel's Avatar
I know there are a couple LED projectors that have USB inputs that can deal with most of the standard picture and video files. Benq IIRC and at least one other. I do not know if any of the bulb based machines do this yet as I have not been looking at them in ages. I need a new projector (or bulb replacement for one of my two Benq machines) which is why I know the LED variety does offer support in this arena. FWIW, I used to run static images on my eight by sixteen foot permanent backyard screen. I would vary between different night time views of city skylines. In the environment I had built around my setup, you could get the feeling of being in those cities, sitting on my back deck and drinking coffee, etc. Here's a picture I took one night. I do not know which city skyline is shown in this picture. I have a bunch of them. Somebody will recognize it I'm sure.
Enjoy.
The Tim Channel is offline
post #4 of 4 Old 04-05-2014, 01:33 PM
Ftoast's Avatar
Quoted: 1921 Post(s)
Liked: 625
Many inexpensive bulb-bases PJs can play pictures from a USBthumbdrive, but most can't play video from it. Almost all portable LED PJs can play pictures from USB and many can play video from USB too. For pictures/slideshows from an inexpensive PJ it's hard to go wrong, they're almost ALL capable in large because most are considered business models.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
Reply Outdoor Theaters
