Wanting to get music pool side. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-22-2013, 01:27 AM - Thread Starter
Shane1's Avatar
Hey all I'm looking for a simple permenant solution to get some music out by the pool. I would like to use 2 or 4 speakers at ground level. I figured I would list the components I have on hand and see what we can make use of. I have a wireless network, an old netbook, smartphones and an ipad. My pool is in range of my wireless network and I have access to 120v outlet near the pool. I will mainly want to listen to pandora or itunes out there. I've researched it a bit and seems like an outdoor cabinet with a receiver/amp might be the easiest option but I though I would ask for any other opinions you all have. Budget for this is 2 -300 bucks.
TIA!
Shane1 is offline
post #2 of 2 Old 04-22-2013, 06:24 AM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 95
Just get a Sonos bridge and Sonos Amp and you'll be all set.
www.Sonos.com
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
Reply Outdoor Theaters
