Outdoor TV Mounting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-25-2013, 09:57 PM - Thread Starter
lpchris85's Avatar
Hello all,
I would like to mount a TV under my newly constructed patio. The trouble I am having is that I need a ceiling mount that can swivel (360 degrees is preferred). I also need it to have an arm that will allow me to fold up the TV towards the top of the patio ceiling, keeping it out of the way when not in use. I checked popular mount makers like Chief and Sanus, but I cannot seem to find something that meets these requirements. Will I need to have a fabrication shop make it? Or is there a pre-made option I am not able to find by simply googling? Thanks in advance!
lpchris85 is offline
post #2 of 3 Old 06-04-2013, 06:03 PM
jnabq's Avatar
Liked: 39
You might find a "telescoping tv mount" that will suffice? Try your googlefu with that.
jnabq is offline
post #3 of 3 Old 07-03-2014, 02:35 PM
inlandsurf's Avatar
Bringing up an old thread....I am looking for the exact same thing as the OP, any advice?
inlandsurf is offline
Reply Outdoor Theaters
