Projector on a shaded lanai - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-04-2013, 07:56 AM - Thread Starter
QuadConPana's Avatar
As is true for most people in SW Florida, our lanai makes a better living room than most people's living room does. The only thing missing is a home theater. We thought about mounting an LCD until we learned that condensation from temperature changes can be deadly even if your screen is shielded from rain. And, the prices of the outdoor LCD's are beyond what we care to spend. A projector, on the other hand, would be easy to bring into the house when not in use.
Unfortunately, everything I can find about outdoor projector application is aimed at people who want to create a drive-in theater type of experience. In fact, even reviews of indoor projection equipment assume that you want a 100"+ screen. So, because everyone is discussing enormous pictures, we are told that we need an environment with little or no ambient light.
So, finally....
Are there any reasonably priced projector/ screen combos that might do reasonably well in a 400-1000 lux environment? (Outdoors, in the shade) We would only want it to create a 50-60 inch diag image. Imagine the projector between the two chairs and the screen a few feet behind where the picture taker was standing.
Thanks in advance for your help.
QuadConPana is offline
post #2 of 2 Old 06-04-2013, 05:57 PM
jnabq's Avatar
Liked: 39
Maybe one of the best "ambient light" setups I've seen, and a related discussion that might help discussing some screen material that can help in some situations. http://www.avsforum.com/t/1470680/theater-bar-game-room-design-considerations-ambient-light-and-projector-specs#post_23262624
http://www.avsforum.com/t/1361269/110-sf-v2-1-3-0-floating-sintra-screen-w-backlighting-videos-too#post_21043092
One thing to consider, normally brighter will mean noisier, but sounds like a cool idea.
jnabq is offline
Reply Outdoor Theaters
