Screen Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-02-2013, 08:17 AM - Thread Starter
woody1313's Avatar
Last years screen 8' x 11' made of 1x2's frame with painters drop cloth stapled tight and bolted to 4" PVC pipe. It worked out well for a inexpensive outdoor theater screen. but storing was a problem.
This years screen upgrade 10' X 18'. I found an 18' motorized awning from craiglist for $70.00. For screen material I use a billboard (unused) tarp which was suggested by AVS member Cool Face. Thanks Cool. Also i use a few tarp clips and ball bungees wrapped around the 4x4 structure to smooth out wrinkles
Woody1313
woody1313 is offline
post #2 of 5 Old 09-05-2013, 04:42 AM
DtommyD's Avatar
Originally Posted by woody1313 View Post
Last years screen 8" x 11" made of ... /quote]
If your buying a new projector, buy more lumens than you will use. Running it in "Eco Mode" makes your bulb last 20-40% longer and reduces noise and heat.
DtommyD is offline
post #3 of 5 Old 09-05-2013, 06:34 PM - Thread Starter
woody1313's Avatar
post #4 of 5 Old 09-06-2013, 12:57 AM
DtommyD's Avatar
I was trying to make a joke and messed up the quote code. The original post has the dimensions listed as inches not feet. See? Funny. "Is this thing on?"
DtommyD is offline
post #5 of 5 Old 09-06-2013, 07:48 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
I got it.
I'm just sayin'.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
Reply Outdoor Theaters
