Recommendations for a 40" - 55" inch TV outdoor column mount under a covered outdoor patio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-12-2013, 04:05 PM - Thread Starter
RobertTX's Avatar
I am having a covered outdoor patio built and want to amount a 40" - 50" TV to a brick column. I will need the TV to rotate and tilt (mounting it fairly high).
Looking for suggestions as to what is a good reliable brand and can withstand the outdoor elements (it will be under the covered patio but will be exposed to humidity, etc.)
Thank you.
RobertTX
RobertTX is offline
post #2 of 2 Old 09-13-2013, 07:50 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sunbrite TVs are designed for outdoor installs.
If you hire someone, he can find a case for a cheaper TV. These are usually for commercial installs (hence the pro rec). Case has heater and/or blower.
If you dig, you might be able to come up with a solution on your own.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Outdoor Theaters
