Outdoor Patio - Projector / Speaker Connection Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2014, 07:44 AM - Thread Starter
sathyakamaraj's Avatar
I am starting the Patio construction in 3-4 weeks after years of waiting. I thought installing projector and getting the speakers connected to it will be simple. But now i am getting stuck....
Size of the Patio : 13' X 29'
Target : Watch Movies - Games on Projector , Play Music
Planning to buy Outdoor speaker AP840 - 4 Qty - mounted at 4 Corners.
Currently I have Onkyo 3007 on the Second floor closet to run the media room.
Is it possible to use this Onkyo 3007 to run the speakers outside, and play video ?
Live till die
sathyakamaraj is offline
post #2 of 3 Old 02-22-2014, 11:35 AM
The Tim Channel's Avatar
If you plan to run speaker wires a really long distance you'll need step-up transformers. If it were me I'd probably just install a cheap HTIB setup for the outside permanently. Then you have stereo outside all the time and it's immediately available for when you want to use for movies. You can get a cheap, but functional HTIB pretty cheap at Walmart these days unless things have changed since I left the US a few years ago. Enjoy.
The Tim Channel is offline
post #3 of 3 Old 02-24-2014, 09:24 AM - Thread Starter
Thanks Tim...I was thinking the same -
May be I should buy Cheap Receiver and put it in the closet as it is - Run speakers wires from the receiver and remote extender...
whenever i want to watch tv or play games - connect HDMI port manually from Media room to this one...
will be pain the @$$ - but i probably watch it outside - Twice a month....
Now i need to find CHEAP receiver - with HDMI ports / able to play music from cellphone through network
Live till die
Reply Outdoor Theaters
Onkyo Tx Nr3007 140 Watts 9 2 Channel Av Surround Home Network Receiver Black
