Getting Direct TV to my Outdoor patio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2014, 07:32 AM - Thread Starter
Liked: 0
Hello,
First time poster, long time lurker. I have received so many good tips from this site that I was able to run my whole house entertainment system. Hopefully I am in the right forum for my question.
Now that my interior home is completed I am concentrating on my back yard. I want to run Direct tv to my Pergola. The problem is the patio is 25 feet from the home on the backside of the yard in the corner. A pool between the honme and patio. I was considering buying a splitter and running cable underground along with a RF so I can control the box from outside. Is that too long of a run? I would need to go up into the wall and then out of the attic and down the exterior wall, underground 25 feet to covered patio.
I am open for any ideas at all if it will prevent me from digging and burying cables. Direct Tv also has a wireless box now but I am not sure that distance will be covered.
Cheers!
bhorne3535 is offline
post #2 of 2 Old 06-23-2014, 11:29 AM
jwh92020's Avatar
Originally Posted by bhorne3535 View Post
Hello,
Cheers!
I can't speak to Direct TV equipment, but my Dish Network Joey worked at 80 feet from my router. Actually, it worked at 110 ft, but the signal strength was in the low 70s. I would think you should be ok with a wireless Direct box.
jwh92020 is offline
Reply Outdoor Theaters
