New PA Setup Questions / Advise - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By luner99
  • 2 Post By redcar54
  • 1 Post By Ttbhg
post #1 of 13 Old 07-01-2014, 08:58 AM - Thread Starter
luner99's Avatar
So I am looking at getting a new PA setup for the outdoor theater setup. I already have the projector, BR player and screen and looking at audio.
At first I thought I would go with a small mixer and 2 15" PA speakers (JBL EON 515XT) for stereo audio and I would be set. The 15"s should give me some decent low end bass for those parts of the movies that need it.
Now I am wondering if I should go with smaller left and rights and add a separate sub.
Let me know what you guys think. Or if I am going way overboard for what I am trying to do. This will just be in backyards for my family, maybe some friends and neighbors occasionally. The setup will be stored in the garage when not in use.
Thanks for all the help!
luner99 is offline
post #2 of 13 Old 07-02-2014, 12:11 PM
Paul Hovey's Avatar
The JBLs will definitely cover it. May be overkill. I use 6”bookshelf speakers and an 80 watt sub and have no problem covering a crowd of30-40.
Paul Hovey is offline
post #3 of 13 Old 07-11-2014, 09:58 AM - Thread Starter
luner99's Avatar
Anyone else that has PA's out there? Please let me know what you are using so I can get a better sense of what I should get - 10", 12" or 15"... I can get a pretty good deal on some EON 510's (10") or the EON 515XT's (15") right now and am waiting to place the order until I get some feedback.
Please let me know what is working for everyone! Thank!
kenny555 likes this.
luner99 is offline
post #4 of 13 Old 07-27-2014, 01:21 PM
redcar54's Avatar
I have Electro-Voice ZLX-12P's with 45 ft of shielded cable for each one, LTO ZMX52 sound board Proline speaker stands 6 ft. Screen 14.5 Gemmy blowup. Optima EH415. All of speaker setup went to Guitar Center for cost $1000. I didn't want to make a mistake on speaker setup, and it was more then worth the price to have a great setup for sound. I don't really push the sound at all with this setup, would suggest you check sound from different speakers at Guitar Center or some place like it before you buy. I would not change anything except screen at this point looking at making 16 by 9 ft for next year, EH415 can handle it easy.
sqa4life and kenny555 like this.
redcar54 is offline
post #5 of 13 Old 12-12-2014, 04:37 PM
kenny555's Avatar
well I guess I may be overboard I use equipment that i already have. I just invite all the neighbors . I have 2 ev elx115p and 1 ev elx118p subwoofer. sometimes i just use my portable technical pro wasp100wbt. it works ok plus it has a battery that will give you long picnic music without ac.
Name:	2013-11-15 20.03.05.jpg
ID:	418106   Click image for larger version
Name:	2014-08-09 14.24.37.jpg
ID:	418114   Click image for larger version
Name:	2014-08-09 14.29.18.jpg
ID:	418122   Click image for larger version
Name:	2014-08-09 14.26.11.jpg
ID:	418130   Click image for larger version
Name:	2014-08-09 14.27.15.jpg
Name:	2014-08-05 16.42.15.jpg
ID:	418146   Click image for larger version
Name:	2014-09-18 12.05.08.jpg
kenny555 is offline
post #6 of 13 Old 12-12-2014, 05:18 PM
kenny555's Avatar
this is the Technical Pro wasp1100wbt portable speaker that i sometimes use. Not very much bass but it works when i don't want to setup all the gear.It has a 12" driver and a tweeter. I believe it was under 250.
Name:	2013-05-05 08.47.23.jpg
kenny555 is offline
post #7 of 13 Old 12-19-2014, 08:34 PM
Quoted: 16 Post(s)
Liked: 6
How do you like your camp 144? I've decided I want an backyard theater and keep going back and forth on that model or a Carl's 9x16. Do you feel like the 144 is big enough?
Ttbhg is offline
post #8 of 13 Old 12-19-2014, 11:23 PM
kenny555's Avatar
I was looking at the same kit from carls place, but i didn't want to spend much. Plus i like the idea its portable with a carrying bag. Everyone will enjoy it no matter which one you choose. its pretty heavy for the bag that comes with it. about 40lbs.but i think if i was going to leave it outside for the summer i would get the one from carls place.
kenny555 is offline
post #9 of 13 Old 01-15-2015, 06:19 PM
sqa4life's Avatar
Quoted: 30 Post(s)
Liked: 37
I know this is an old thread, but I recently bought two ZLX-12P's. The sound they produce is awesome. However, I can't stand the hiss/noise when the system is in standby mode (all music sources paused/stopped). I thought it was my equipment that causes the noise so I brought it back to Guitar Center to test on their cables and their mixer; same noise. They also tested on another speakers and they have the same kind of hiss/noise. I guess all powered speakers does that. The noise only notice when the speakers are hooked up to a mixer and bring up the volume 1/2 way.
I am thinking of returning the ZLX-12P's (powered) and buy two ZLX-12's (Passive). But, I am not sure if my Yamaha RX-A2000 receiver will be able to handle the two ZLX-12's
sqa4life is offline
post #10 of 13 Old 01-15-2015, 06:39 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Have tried turning down the gains on your speaker?
Manic1! is offline
post #11 of 13 Old 01-15-2015, 07:06 PM
sqa4life's Avatar
Quoted: 30 Post(s)
Liked: 37
I left all settings at factory default. I also turned the master volume to -2.
sqa4life is offline
post #12 of 13 Old 01-16-2015, 12:30 AM
redcar54's Avatar
I don't have any hiss/noise problem with mine. Not sure of the setting on mixer or speakers. I'm sure i had the speakers set up to +10 without any hiss. Last time used was in a church hall
at the start of November.
redcar54 is offline
post #13 of 13 Old 01-16-2015, 03:36 AM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
You need to properly set your gains. I'm no expert but first thing I would do is lower your gains on the back of the speaker until you here no or very little hiss. Whats the rest of your set up?
Manic1! is offline
Reply Outdoor Theaters
