5050 led strip outdoor install Qs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-09-2014, 01:32 PM - Thread Starter
Liked: 0
Hey Guys, looking to get some info on an outdoor led strip install around my deck. Here are my specs....
Looking to use 4 rolls of 5m (30 LEDs/m - 150/strip) 20m total. To reduce dimming, I plan on connecting only 2, 5m strips together (daisy chain) and power them with a dual output controller.
Wire plan...
Power source ---- ir controller ----led strip--- led strip
(From ir controller)|---- led strip ---- led strip
My list of components...
Led strips - http://www.ebay.com/itm/251582389009...%3AMEBIDX%3AIT
Power source - http://www.ebay.com/itm/161274098751...%3AMEBIDX%3AIT
IR controller - http://www.ebay.com/itm/331282432950...%3AMEBIDX%3AIT
Q's
1. Will this power source and controller be powerful enough to control both sets (10m) of lights without dimming and/or burning my house down.
2. Should I add these amps in between each of the two sets to boost the amps/watts?
Amp- http://www.ebay.com/itm/161387972737...%3AMEBIDX%3AIT
3. If I would "dual feed" each end of the two strip, would I need the amps?
Any help is appreciated. Thank you.
KB25
KB25 is offline
post #2 of 4 Old 08-13-2014, 02:16 PM
Liked: 0
Wire plan...
Q's
KB25
I've installed 5050 strips around my screened in pool enclosure and under my gazebo. I bought all the strips on ebay and they came with wall transformers, IR controllers and 144 key remotes. Paid around $20 per 5 meter (16 ft) set. I purchased no additional power supplies or controls. So far the only problem I had was the peel and stick backing is junk. I bought 1/2" wide rolls of VHB outdoor tape on ebay. I've also put the LED strips under all my kitchen cabinets. Latest addition to my gazebo is a projector screen and optoma GT760 projector.
stallionent is offline
post #3 of 4 Old 08-13-2014, 03:54 PM
Liked: 0
Here's a couple of pictures of my setup. Note the LED's under the top.
post #4 of 4 Old 08-03-2015, 12:31 AM
Liked: 0
I use it on the camper, works very well. I did put some heavy duty 3M on the ends just for my worry. 80MPH down interstate and still holds well. I would advise to get at least 15ft of extra wire to place the controller under camper out of the rain. I would also use liquid electrical tape for the joints. The pic is with the awning closed, open it gives off even more. With remote you can dim as needed. SuperNight LED!
diwade29 is offline
Reply Outdoor Theaters
led strip 5050 led driver
