Backyard Screen Advice - should I buy? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By b curry
post #1 of 3 Old 05-27-2017, 08:21 PM - Thread Starter
MeanMachine's Avatar
Quoted: 254 Post(s)
I see these 12 foot blowup screens anyone use before? 160 bucks good reviews but I also see hard screens you can put up too outside ....
Anyone?
MeanMachine is offline
post #2 of 3 Old 05-28-2017, 03:22 AM
Quoted: 1268 Post(s)
Liked: 714
Avoid the blow up models and get a regular screen. The picture quality is so much better and the inflatables stink even with a light breeze. Camp Chef makes some that are reasonably priced on Amazon. Their only disadvantage is they will take a little longer to set up. Once you are used to it you will do it in 10 minutes.
Ellebob is online now
post #3 of 3 Old 05-28-2017, 05:53 AM
b curry's Avatar
Quoted: 479 Post(s)
Liked: 279
Anyone?
I would stay away from the cheap blowup screens. They are not very stable in even a light breeze and the screens tend to have wrinkles. A good blowup screen is expensive and are still sometimes noisy.
If you want a 12' screen I would suggest this one:
http://www.visualapex.com/Projector-...175&Category=4
If you're willing to do a little work yourself I would go with one of Carl's PROJECTION SCREEN KITS:
http://www.carlofet.com/projector-screen-kits.html
The Camp Chief screens would be a third choice for me. They're ok but they are designed to work as both a front and rear projection screen and as such, they are a comprimise regarding image quality.
MeanMachine likes this.
b curry is offline
Reply Outdoor Theaters
