Projector recommendation - 21ft wide x 9ft tall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-04-2017, 03:47 AM - Thread Starter
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
Question Projector recommendation - 21ft wide x 9ft tall
Hi,
I bought a Carl's place screen.
I need a projector to light up 21ft wide x 9ft tall (2.4 aspect ratio). I have a Panamorph UH480 lens that I can use.
I'm having trouble finding a projector that:
  • Suports vertical stretch (do I need to use an A-lens?)
  • Lets me have at least a 25ft throw (some of the things I see are fixed throw)
  • High enough lumens to produce a watchable image (4500-5500+ lumens?)
Budget is under $5000, I'm open to stacking or blending if you can give information on that - but I'm guessing neither of those techniques are needed.
ELmO
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
post #2 of 4 Old 08-04-2017, 04:02 PM
Ftoast's Avatar
Quoted: 2253 Post(s)
Liked: 709
If you're looking for both brightness AND contrast, a pair of Epson 3700 projectors can keep you around 14ftL-16ftL with impressive native-contrast while their optical lens-shift can help you align the pair more easily than models without lensshift.
They also feature a large amount of zoom-range which barely affects their brightness.
Being hometheater projectors rather than business models, there's a better chance they support vertical stretch, but I'm still not sure whether they do or do not.
The natural 10%-20% light lost from additional optics (particularly lenses which don't cost a fortune) often leaves many A-lenses with little or no real brightness advantage, so I wouldn't personally worry too much about NEEDING a projector that supports vertical stretch.
A pair of 3700's can keep around 14ftL-16ftL on a 21ft-wide white Carl's screen without using an A-lens.
They'll need to be setup at least 28ft-29ft back from the screen to fill it...If you want to place them farther back, you can go as far as 40ft-45ft back if needed, or anywhere between ~29ft-44ft.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is offline
post #3 of 4 Old 08-29-2017, 05:36 PM - Thread Starter
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
I ended up buying an Epson G7500U (refurbished). Let's see how it does, should be about 20ftL without A lens. Also does 4k enhancement so maybe the pixels lost from zooming won't be as visible from seating area which is 30ft away.g
Projects:
Game room:
elmalloc is offline
post #4 of 4 Old 09-17-2017, 06:11 PM
Quoted: 52 Post(s)
How do you like it?
Sent from my SM-N910V using Tapatalk
maseline97 is offline
Reply Outdoor Theaters
