Recommendations for cheap rear-projection screen material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-01-2006, 01:19 AM - Thread Starter
Dodo Bird's Avatar
First off, I would like to thank everyone in this forum for sharing their knowledge and experiences.
For Halloween I decided to do a rear projection movie from my garage. Based on some prior posts I purchased two frosted shower curtains from Walmart. Total cost - $6. Showed Corpse Bride and the neighbors loved it and are now asking for a monthly movie night. So I'd like to get a slightly better screen!!
Can anyone recommend relatively cheap material which would make a good rear-projection screen. Thanks.
Dodo Bird is offline
post #2 of 4 Old 11-01-2006, 07:49 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Try the 9.99 frosted shower curtain from Walmart. It is a heavier guage vinyl. I bought both but only used the 2.99 one for Halloween. Haven't tried the heavier one yet.
Good luck!
Tom
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 4 Old 11-01-2006, 08:34 AM
victor-eyd's Avatar
The Mainstays $2.98 frosted clear curtain is from Walmart. No hotspotting issues. Works GREAT!! Buy two curtains and use clear 2" tape and have a screen 70" x 140". I also bought the heavier shower curtain Tom talked about and the difference between the two is nil. Besides, for the price of one you can have 3 curtains!!
As to better quality, the only way I could see improvement is to heat out the wrinkles and folds. That or get true rp material which costs wayyy more than shower curtain.
http://www.imagestation.com/picture/...8/ec3e6adf.jpg
Note Marge's hair
Victor
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #4 of 4 Old 11-15-2006, 03:07 PM
vttom's Avatar
FYI - This summer I cut open a couple of white plastic kitchen garbage bags, laid them flat and taped them together, and hung them from a wooden dowel supported by a couple of 2x2 screwed into the railing of my deck. Aside from the seems, which were not all that noticable, it made an outstanding outdoor rear-projection screen. MUCH better than the poly/cotton bedsheet I'd tried earlier.
vttom is offline
Closed Thread Outdoor Theaters
