professional power amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-24-2007, 08:24 AM - Thread Starter
taurean23's Avatar
concert power amp
I am designing a outside home theater in my backyard, I want to know if its possible to connect a professional or concert level power amp to my denon avr 5805. My outside theater will be 5.1 and I want the fronts and center to be professional level speakers with a 500w power rating.
The denon will act as a decoder still for dolby digital and dts ,but will also power the back speakers. Do you guys know of any power amp that has a 2500-3000w capacity that can connected to the denon's preouts?
the speakers i am thinking of using for my front left and right are these
JBL JRX 125
they are rated at 500w in 8ohms i believe;however, the issue is is there an amp with a total rating of 2500-3000w that can provide enough headroom to drive two of these guys?
I seen professional crown amps with these power compacities but they all have XLR inputs, is there a way you can convert denon's rca preouts into XLR inputs?
taurean23 is offline
post #2 of 6 Old 02-28-2007, 06:17 PM
apatel's Avatar
Crown amps are very good for high-power situations, and there exists several types of converters for unbalanced to balanced (RCA to XLR). AudioControl makes one which works exceptionally well.
apatel is offline
post #3 of 6 Old 03-01-2007, 07:23 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
jeeze-peezy! How big is your back yard? I run 1000W total in a HTinB and it's fine outdoors.
Tom
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #4 of 6 Old 03-30-2007, 12:01 PM
FlashJim's Avatar
I think I've found a moniker..."The Thread Ender"...seems like every time I reply to a thread, it ends
Just to prove you wrong ...
Behringer EP2500. Cheap, powerful and surprisingly clean.
FlashJim is offline
post #5 of 6 Old 03-31-2007, 10:15 PM
poormanq45's Avatar
I second the EP2500 recommendation
Also a EP1500 would work good for the rear channels or bridged for the center channel
poormanq45 is offline
post #6 of 6 Old 04-08-2007, 01:14 AM
Resaebiunne's Avatar
Originally Posted by taurean23 View Post
concert power amp
JBL JRX 125
You don't need 2000 watts of headroom. If the speakers are rated for 500 watts each, you'll want to match that at least, but you don't have too.
You'll have to fork some serious cash for a 2kw + amplifier, not to mention you'll need a proper electric hookup, as a standard 15 amp circuit will be overloaded if it should happen that you max your amplifier.
Besides that, I doubt you'll ever need that much sound for a movie. Most of the pro speakers are extremely sensitive, and will be MORE than loud with just a few watts of power.
Resaebiunne is offline
Reply Outdoor Theaters
