HT Projector or Multimedia? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-22-2007, 10:37 PM - Thread Starter
jakedog13's Avatar
Would I be better off buying (I'm not tied to these brands) a HT quality projector in the range of an optoma hd70 or sharp dt100 (slighty under $1K) or go towards the brighter models such as a sharp xr-10xl ($800). I want to be able to show a big image on the garage (16' x 9' or bigger) and not necessarily wait for total dark. On the other hand, I'd definitely consider using this in the basement in winter, so would the data type projector be hideous inside? Would the HT projector be able to put up a big bright pic outside (kids movies mostly, so not tooo particular about outdoor quality).
jakedog13 is offline
post #2 of 3 Old 03-23-2007, 09:51 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
I use a Sharp xr-1s both outdoors and indoors (until I complete my basement). Works great outdoors and fine indoors. Can't use it permenately becasue it won't do upside down from the ceiling.
Tom
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 3 Old 03-23-2007, 11:49 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
HT all the way!!! especially HD...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Reply Outdoor Theaters
