Outdoor Pull-Down REAR projection screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2007, 10:59 PM - Thread Starter
KostaVan's Avatar
Hey everyon!
I am wanting to create a set-up outside with the projector inside using a rear projection screen. There is a balcony by the pool and want to mount it low on the side of the balcony and have a rope where I can pull it down when it needs to be used.
I am wanting around 140-160 inches diagonal 16:9 screen but also need it to have space on the top to make up for the length it needs to come down when pulled. I also need it to be weatherproof when retracted.
What are my options???
THank you!
-Kosta
Edit: I'm thinking I might be able to ceiling mount under the balcony if I can't find a pull down with enough height to compensate. Therefore I wouildn't need much above the screen. I'd still prefer to wall mount as it would be less noticeable.
Any ideas?
KostaVan is offline
post #2 of 3 Old 05-03-2007, 08:37 AM - Thread Starter
KostaVan's Avatar
I've been in contact with da-lite and they say this is not really feasible.
They say I should use a more temporary solution as the fabric will not hold up outdoors.
So now I need recommendations on an easy setup that will be a breeze to put up and take down.
Any ideas?
KostaVan is offline
post #3 of 3 Old 05-03-2007, 09:04 AM
mixinbeatz's Avatar
I would check out stumpfl, they are not pull downs but make some nice aluminum framed screens. They are a little pricey, but they have some cool solutions for rear projection. A cheaper solution might be calling around to AV rental companies in your area and see if someone has a used dalite fast fold frame they want to get rid of. You might be able to find a used frame and buy new material for it. Takes 5 minutes to attatch the screen to the frame. The 16:9 is going to be a problem though, since most rear screens like this are made for computer projection in professional applications.
mixinbeatz is offline
Reply Outdoor Theaters
