Outdoor HDMI/Component Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-09-2007, 07:12 PM - Thread Starter
mbamenra's Avatar
Hello, this is my first post on this forum. I just bought a projector (IN72) for occasional use outdoors to show dvds and TV and plan to purchase and permanently install a 50 foot HDMI or Component video cable to run from my equipment inside the house to the projector outside.
In consideration of weather and the elements, will a thick 24 awg HDMI cable or any component cable work for an outdoor home theater setup? Any advice would be helpful. Thanks.
mbamenra is offline
post #2 of 4 Old 07-22-2007, 10:06 AM
Ruben00's Avatar
im looking to do the same thing, anyone?
Ruben00 is offline
post #3 of 4 Old 08-09-2007, 09:38 AM
jpturner's Avatar
The best signal in, will give you the best picture out.
If you go the component cable route, try here, they are a forum sponsor:
http://www.ramelectronics.net/html/comp-video.html
jpturner is offline
post #4 of 4 Old 08-11-2007, 06:22 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
I use HDMI cables with my set up. It just makes it a lot easier. One for the HD DVD player and one for the Blu ray player. Both go into my Onkyo 605 and then of course a HDMI out from there goes into my Sanyo Z5... It is almost like cheating!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Reply Outdoor Theaters
