Nec Gp3000 - AVS Forum
post #1 of 6 Old 06-25-2008, 09:25 AM - Thread Starter
radeng9805's Avatar
Stopped powering up. No lights on the back panel. Where the heck is the primary fuse on this thing and how do you access it? Thanks for any help.
radeng9805 is offline
post #2 of 6 Old 06-25-2008, 01:27 PM
Curt Palme's Avatar
Chances are the main power supply has blown it's proprietary chips within the power supply and it has died. There is one fuse in teh SMPS, but guaranteed it's OK. I have one working GP3000 in minty shape left that I'll sell cheap if you're interested. I can try to repair the SMPS, but chances are I can sell you a whole other set for less than it would cost to repair the supply.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is online now
post #3 of 6 Old 06-26-2008, 03:18 AM
jantje112's Avatar
Do a search in the archives. THe gp3000/5000 are known for this problem.
No fix for it
jantje112 is offline
post #4 of 6 Old 06-26-2008, 10:14 AM - Thread Starter
radeng9805's Avatar
Dang. Curt, has the unit you have been modified to prevent the dreaded Hybrid failure?
Anybody want a dead GP3000?
post #5 of 6 Old 06-26-2008, 04:41 PM
Prehjan's Avatar
The chip in question is made of "unobtanium"
Martin
Prehjan is offline
post #6 of 6 Old 06-26-2008, 06:51 PM
Curt Palme's Avatar
Nope. It works, but who knows for how long. It's not worth spending 2 hours to go through the set. But I'll sell it cheap. As is.
Reply CRT Projectors
User Tag List
