n00b hello and a quick question about a Barco 808 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-22-2008, 09:50 AM - Thread Starter
Cavi Mike's Avatar
*Update 3/4/2016 - This monster is up for grabs. See post #15*
I didn't see a newbie forum so I suppose I'll make this my newbie post. Names Mike, I don't know much about anything HT related, well modern HT anyways, I'm still using a 40 y/o MCS reciever that I've been keeping alive and some many-times-rebuilt speakers of the same age.
Well, I found a killer deal on a Barco Graphics 808(non S) and I'm pretty psyched about getting her all setup. The question I have really isn't about the unit itself but I found out the Data model retailed for almost $21K USD and I'm curious what my Graphics model went for.
See you all on the boards!
pearls ain't free
Cavi Mike is offline
post #2 of 15 Old 08-22-2008, 11:17 AM
kschmit2's Avatar
does it really matter?
kschmit2 is offline
post #3 of 15 Old 08-22-2008, 11:32 AM - Thread Starter
Cavi Mike's Avatar
Yes. My jaw dropped to the floor when I found out how much this thing is worth. When I looked at it I actually thought twice about purchasing it. Now, I actually feel as if I ripped the guy off even though I gave him his asking price. Basically I want a solid number to make other peoples jaws drop to the floor. If you think it's some type of envy thing and you think you have me all figured out, just stop now.
pearls ain't free
post #4 of 15 Old 08-22-2008, 12:45 PM
draganm's Avatar
Quoted: 21 Post(s)
Originally Posted by Cavi Mike View Post
Yes. My jaw dropped to the floor when I found out how much this thing is worth. Basically I want a solid number to make other peoples jaws drop to the floor. If you think it's some type of envy thing and you think you have me all figured out, just stop now.
it's worth about 500 bucks.Sorry if that doesn't impress your firends but we're here because we enjoy the hobby.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #5 of 15 Old 08-22-2008, 01:07 PM
David_Web's Avatar
500$ with good tubes that is (maybe some more if it's in really good shape). If they are burned it's less. IMHO.
BTW BG808 was 21995$ BD was only 16995$
So how much did you get it for?
David_Web is offline
post #6 of 15 Old 08-22-2008, 02:36 PM
PeriSoft's Avatar
Expensive or not, it's an awesome projector (I've got the S version). Take the time to learn how to set it up, and enjoy it - forget about how much it used to cost!
PeriSoft is offline
post #7 of 15 Old 08-25-2008, 11:21 AM - Thread Starter
Cavi Mike's Avatar
That totally blows me away that this thing was more than my car. I don't think it's even really set in just what I have and it probably won't until I see it in action for the first time.
It was used at RIT in an auditorium and I'm told it only has 5000hrs on these tubes. I'm inclined to believe him, I see no reason why he would lie given how little he asked for it. It even has the original lens covers.
I've been reading as much about this unit as I can, mainly the Curt Palme website. Unfortunately this came sans manual but I'm sure I'll be able to find anything I need to know thanks to the internet. I doubt I'll be able to share much but I'll definitely absorb as much as I possibly can from here also.
pearls ain't free
post #8 of 15 Old 08-25-2008, 11:55 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Hi Mike welcome to the forum! I live in Western new youk as well. I have Electrohome marquees but if you need help setting it up I might be able to help out. There is also e member in Pembrook i thnink who has a barco, he is on the Curt palme forum, you should join there as well. The Crt Forum there is visited more often than here. I think the local barco's guy screen name is Gonyr.
Athanasios
nashou66 is offline
post #9 of 15 Old 08-26-2008, 10:56 PM
Vic C's Avatar
Barco projectors are simple to set up compaired to others.
Yea the se old projecotors sold for a ton of money in their time but are mostly all obsolete and worth less ans less each day.
5000 hours is quite a bit of hours so I know you will see some burning on those tubes and that in its self is why you got it cheep. So dont be supprised if actually needs a re tube. You never said how cheep you got it for but thats ok you dotn have to.
They are a fun machine and easy to set up and kep looking good. Just check it out when you get it and see if its worth gettign all involved in if the tubes are shot. It was in a auditorium so it may have been run hard.
Vic C is offline
post #10 of 15 Old 08-30-2008, 09:12 AM
gonyr's Avatar
I'm here, too, but only as a lurker. See, 1st post. I'm certainly no expert in any way, but I can help out with the basics. BTW, Pendleton (near Lockport) not Pembroke.
gonyr is offline
post #11 of 15 Old 08-30-2008, 03:35 PM
PeriSoft's Avatar
Too bad everybody upstate is so far west... where're my Fingerlakes peeps? Ithaca rep-rah-ZENT!
PeriSoft is offline
post #12 of 15 Old 08-30-2008, 07:09 PM
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 74
Original sell price is meaningless. The first IBM PC sold for $5000 but now is found in the dump. You can't sell an XT for even $5.
(Not to say that CRT projectors should be found in the dump of course... I run a Barco myself!)
Kal
kal is offline
post #13 of 15 Old 08-31-2008, 10:45 PM
Prehjan's Avatar
Cavi Mike
...foremost I wanna welcome you to the "dark side" and say that in no way shape or form CRTs are an obsolete technology...(..maybe the lower end ones that have no bandwidth for anything but a 480i picture!)
I started with a barco 801s and moved up to a marquee and I can say that short of spending multiple times the amount you would spend on a decent CRT you will never get the same picture...but close enough to a wel set up CRT, but then again at multiple times the cost!
Just try and enjoy it and if you have any questions we will be more that happy to try and answer them for you!
I would think that a 8xx series manual is the same for your pj...
There is a really good site out there that has this manual and alot of other useful info for the barco 8xx series...I m sure someone here will remember it, or just google it and see what showes up!
Anyhow , welcome and have some fun
Martin
Prehjan is offline
post #14 of 15 Old 09-04-2008, 11:25 AM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Mike congrats on the projector. What we forgot to mention that the 5000 hours on 808 also includes standby time. I had an 808 with 14000 hours and the tubes where in pristine shape.
Good Luck
greg1292 is offline
post #15 of 15 Old 03-03-2016, 09:50 PM - Thread Starter
Cavi Mike's Avatar
Nearly 8 years later and I haven't done anything with this. Not many of my projects ever come to fruition. I always buy things that just sound awesome with the hopes of doing awesome things with them - but reality strikes that I have no real motivation - so instead my projects just end up collecting dust and taking up space.
Well, along with a car that sat for 7 years, and a motorcycle that sat for 3, this has to go as well. If anyone is interested in this, I will be giving it away, you just need to cover shipping. Obviously with something of this mass, it will need to be palletized and delivered via freight. Fortunately I work at a factory so I have access to all of what's needed to pack it up at no cost, so you won't need to worry about any of that.
I haven't put it on craigslist yet, I'd rather give it to someone on here that will actually make use of it (unlike myself). If no one here shows any interest, then I'll resort to craigslist.
pearls ain't free
Reply CRT Projectors
