Runco DTV 1100 / Barco 1209s install setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-24-2008, 01:47 PM - Thread Starter
UTIGUY's Avatar
I've got my DTV 1100 home now and trying to do a prelim setup. I'm in the install setup screen trying to center the red and blue CRTs onto the green. I am easily able to do the horizontal adjustments, but cannot perform any vertical adjustments. I loosened the correct nuts and the lenses moved freely in the horizontal plane. But I don't see how the lenses can move in the vertical plane.
I don't know if the distance to the screen is correct, I just set the PJ from the wall until the image was mostly in focus, and the distance that was in the setup screen appeared to be approximately correct.
Any help? Thanks!
Gene
UTIGUY is offline
post #2 of 2 Old 11-24-2008, 02:14 PM
Chuchuf's Avatar
The "toe in" adjustments only move horizontally, not vertically. Any vertical movement is done electronically.
Terry
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
Reply CRT Projectors
