Do you display 1080p on your Sony G70? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 105 Old 12-30-2008, 07:52 AM - Thread Starter
rajdude's Avatar
Ok folks, the tweak-bug bit me again!
I have a Sony G70 fed by a HTPC outputting 720p / 60Hz. I have been very happy with it and have not done anything to it for more than a year.
However I am curious if this can do 1080p.
How many of you G70 owners out there use 1080p on your PJ on a daily basis?
Here is my reason of looking at 1080p:
When I display a 1080p version of (blu-ray) HD DVE's SMPTE RP 133 Resolution Chart on my setup I cannot read the percentage readouts around the squares in the center of the screen. For reference, look at this image:
http://upload.wikimedia.org/wikipedi...PTE_RP-133.png
Anyway, out of curiosity I changed the output of my HTPC to 1080p/60Hz and roughly corrected the geometry (I did not converge but I shut off R and B tubes)
I was surprised to see that now I was able to read the (above mentioned) numbers in that pattern (with only the green gun on.actually with only the red gun on.it is even more clear..forget about only blue it sucks (expected?))
Of course there are no scan-lines visible at 1080p. However I can still easily make out the 1-line on and 1-line off pattern easily (what is it called?) .in both horizontal and vertical planes. Does it mean this PJ is actually resolving 1080p just fine?
I would love to hear your opinion on this.
My setup:
  • Sony G70 PJ
  • Newer HTPC with nVidia 8600GTS card
  • Power DVD8, PDVD 7 and TMT for BD playback.
-Rajiv
rajdude is offline
post #2 of 105 Old 12-30-2008, 08:35 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
The G70 can't fully resolve 1080p @60hz the image is soft compared to running A custom res, Then A LOW HOUR G70 is capable of displaying A stunning image....
The best results can be achieved with A Moome HDMI/Gamma card and A high end stand Alone VP
such as A DVDO VP50pro or similar that can run custom resolutions and has HDMI 1.3 or HDSDI, A Blu-Ray player set to output 1080 24p YcBcR 4:2:2.
and the VP setup to output A custom res of 1920x817 @48hz YcBcR 4:2:2 to A correctly calibrated low hour G70 + Moome HDMI/Gamma combo...
This will get you pretty much the best picture A G70 can produce the end result will Yield A super sharp picture compared to inputing 1080p @ 60hz from A Blu-Ray....
Cheers...
cinema mad is offline
post #3 of 105 Old 12-30-2008, 09:48 AM - Thread Starter
rajdude's Avatar
Hmmm..... How about doing the same thing with a HTPC?
IMHO a HTPC>CRT can also do what your chain of "BD player > VP50 > Moome > CRT" can do.
Full gamma correction is there along with color correction.
My HTPC allows custom resolutions at custom refresh rates.
I have never tried 1920x817. I believe that will be 2.35:1 right?
But what about images which are 16:9...like I watch a lot of HD TV content in 720p native (FOX). That will have to be displayed in either 1280x720p @ 60Hz......which is displayed fine anyway.
But there are plenty of Blu-ray movies with are in 16:9 format. How do you display that on 1920x817 ?
As for 48Hz refresh....... Are you sure you are displaying that refresh rate on the G70?
When I tried 1920x1080p @ 48Hz yesterday, the PJ did sync up but the image was flickering a lot.....definitely not watchable.
I will try out 1920x817 @ 48Hz tonight.
Cheers...
-Rajiv
rajdude is offline
post #4 of 105 Old 12-30-2008, 10:06 AM
JohnHWman's Avatar
Hi Rajdude,
I can say that 1080p48 with reduced porches is OK on G70
Try these parameters in Powerstrip:
Freq.H = 53.946KHz
Sync.V = 47.952Hz
Pixel rate = 118.681MHz
Syncs = H+/V+
Hsize=1920
Vsize=1080
Porchs values :
H_Front=88
H_sync=44
H_Back=148
V_Front=4
V_sync=5
V_back=36
With these parameters while watching HD, it's very difficult to see the 48Hz flicker at 1080p48. On Windows desktop, it's flickering, yes, but almost no flicker when playing HD...
1080p48 @ 118MHz is really delivering a very sharp picture (because pixelclock is under 120MHz) and judderfree. Thanks to the reduced video porches setting that reduce the flicker very well ...
I've been using this setting on G70 (and now on my G90) for years to watch HD-DVD or BR material
John
Home theater enthusiast for over 20 years !
My dedicated HT room !
JohnHWman is offline
post #5 of 105 Old 12-30-2008, 10:56 AM - Thread Starter
rajdude's Avatar
Hi John,
Thanks a lot for these tips!
I will try it out.
May I ask what video card you have?
Last I checked, Powerstrip did not work with newer nVidia cards.
Originally Posted by JohnHWman View Post
Hi Rajdude,
Freq.H = 53.946KHz
Sync.V = 47.952Hz
Syncs = H+/V+
Hsize=1920
Vsize=1080
Porchs values :
H_Front=88
H_sync=44
H_Back=148
V_Front=4
V_sync=5
V_back=36
With these parameters, for me it's very difficult to see the 48Hz flicker at 1080p48 so image is very sharp (pixelclock is under 120MHz) and judderfree. Thanks to the reduced video porches setting that reduce the flicker very well ...
John
-Rajiv
rajdude is offline
post #6 of 105 Old 12-30-2008, 07:22 PM
Mark_A_W's Avatar
Some alternatives:
1920 x 1080i at 95.904 hz Similar to 1080p 48hz but no FLICKER.
PowerStrip timing parameters:
1920x1080=1920,112,128,115,1080,46,5,30,126655,542
Generic timing details for 1920x1080:
HFP=112 HSW=128 HBP=115 kHz=56 VFP=46 VSW=5 VBP=30 Hz=48
VESA detailed timing:
PClk=126.66 H.Active=1920 H.Blank=355 H.Offset=96 HSW=128 V.Active=1080 V.Blank=81 V.Offset=46 VSW=5
Linux modeline parameters:
"1920x1080" 126.655 1920 2032 2160 2275 1080 1126 1131 1161 interlace -hsync -vsync
1920 x 802p at 71.928hz
"C:\\Program Files\\PowerStrip\\PStrip.exe" /t:1920,138,64,154,802,7,3,18,135877,534
Loving my Electric Bike!!
Mark_A_W is offline
post #7 of 105 Old 12-31-2008, 02:05 AM
JohnHWman's Avatar
I've been using Powerstrip with ATI card on my first HTPC. Then for my second (G35) and now my third HTPC (G45), I'm using Intel embedded graphics (IGP) and tweak it (like powerstrip does) with DTD Calculator.
John
post #8 of 105 Old 12-31-2008, 07:31 AM - Thread Starter
rajdude's Avatar
I tried it last night and I have one word.
WOW !
  • Scanlines on 1080p !
  • No flicker (I get no flicker even on my desktop)
  • I can read everything on the SMPTE RP 133 Resolution Chart
Thanks a million for the tip, John!
I don't have powerstrip. My nVidia drivers have these fields I can change in the manual mode. The only fields I did not see are the ones in red below:
Freq.H = 53.946KHz
Sync.V = 47.952Hz
Syncs = H+/V+
Hsize=1920
Vsize=1080
Porchs values :
H_Front=88
H_sync=44
H_Back=148
V_Front=4
V_sync=5
V_back=36
Still I was able to get it working fine.
Anyone who is after 1080p should try this out.
Video was very smooth earlier (720p @ 60HZ), but now it is even smoother WOW!
I know lot of people here want to do 1080p at 72Hz. After yesterday night, I am wondering, why bother? Why stress out the electronics further.
Now for the curiosity-killed-the-cat question:
What the heck are porches and why reducing them gets rid of the flicker at low refresh rates?
googling porches....
-Rajiv
rajdude is offline
post #9 of 105 Old 12-31-2008, 09:18 AM
MikeEby's Avatar
The way I understand it is, it flickers less is because the projector spends less time off before it redraws the image again.
smaller porches = less off time
Ok, here is my question....Let's say you have a stack like Cliff's but 8" projectors both running 48Hz but somehow you could make the 2 projectors retrace times out of phase, would the results be less flicker?
Mike
MikeEby is offline
post #10 of 105 Old 12-31-2008, 09:55 AM - Thread Starter
rajdude's Avatar
Mike,
your idea may work but how do you make them out of phase?
Also I am never a fan of stacks.....it makes an already soft image softer.
I mean CRT PJs throw a soft image (compared to dPJs)
Stacking them makes them even softer.
I suspect your solution may make a stack even more soft.
Mike
-Rajiv
rajdude is offline
post #11 of 105 Old 12-31-2008, 10:03 AM
MikeEby's Avatar
Mike,
Your right about the sharpness, however when I look at the 1:1 pattern at 48Hz on my XG is way better then at 1080p@60Hz because of less bandwidth requirements for 48Hz the flicker on an XG is unbearable at 48Hz with any porch settings that will sync correctly. Getting the 2 projectors out of phase....Any ideas...anyone?
Mike
MikeEby is offline
post #12 of 105 Old 12-31-2008, 10:38 AM - Thread Starter
rajdude's Avatar
I guess you have already tried the porch settings above, right?
I wonder why a G70 would sync to these porch settings and not flicker.....but a XG wont.
Design/electronics difference?
...........the flicker on an XG is unbearable at 48Hz with any porch settings that will sync correctly.
Mike
-Rajiv
rajdude is offline
post #13 of 105 Old 01-02-2009, 01:00 PM
DrBob's Avatar
Hi
I just got my g-70 up with a PS3 for bluray and the new hdmi card from moome and it is doing 1080P pretty well. Picture looks much better than when I ran 720 thru an older crystal image. Churchuf came over to redo the setup with the new output. My g has about 3K hrs on it but I was surprised at how well the image is at 1080p.
Bob
DrBob is offline
post #14 of 105 Old 01-02-2009, 02:20 PM
Mark_A_W's Avatar
G70 has a shorter retrace.
The XG has a pretty picky deflection system. My PG Xtra was more robust - much less likely to foldover or raster ring on the LHS.
Mark_A_W is offline
post #15 of 105 Old 01-02-2009, 04:21 PM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
However I am curious if this can do 1080p..
Have you tried 720@71.928? or 1080i@96?
Ken W setup 720p/72 on Wallace's 9PG next door and it looks great.
Mike,
My storage closet recently restocked... I've recently got some G70's if you want to experiment with a 48Hz x 2 stack. Or 1080i/60 x2.
Or 1080i x4.
Clarence is offline
post #16 of 105 Old 01-02-2009, 06:33 PM
MikeEby's Avatar
Or 1080i x4.
That is one hell of closet...I'm sure AR will take them off your hands.
Mike
MikeEby is offline
post #17 of 105 Old 01-02-2009, 07:58 PM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
That is one hell of closet... I'm sure AR will take them off your hands.
The G70's are currently parked in a corner of my boys' playroom.
Yeah, AR said he wanted to live next door, plus he'd be closer to Wallaces BBQ.
Clarence is offline
post #18 of 105 Old 01-03-2009, 12:39 PM
Fellenz's Avatar
Wow four G70's
How are the tubes?
RGB
CRT Forever
Fellenz is offline
post #19 of 105 Old 01-03-2009, 06:42 PM
MikeEby's Avatar
Originally Posted by Fellenz View Post
Wow four G70's
How are the tubes?
Down boy!
Mike
MikeEby is offline
post #20 of 105 Old 01-03-2009, 07:36 PM
wallace1234's Avatar
Or 1080i x4.
Rajdude,
You need to come up here and see our HT. We are planning on having a "mini-meet" here soon and I'll let you know what the date is.
Ken Whitcomb did an outstanding job setting up our nec 6pg xtra. I hope to get him out here soon for some other work and I would think he could work his magic on your pj as well.
wallace
Life is good, but BBQ is better.
wallace1234 is offline
post #21 of 105 Old 01-03-2009, 09:26 PM
AnalogRocks's Avatar
Ok that's it. Any houses for sale on your street?
You're not Analog, I'm Analog!
AnalogRocks is offline
post #22 of 105 Old 01-03-2009, 09:27 PM
Wow! I just broke 30 post's! I'm excited
post #23 of 105 Old 01-03-2009, 09:54 PM
WOW!!! 30 here, and 30,000 on the other site? Come on down! The house next door is for sale! You'll be right in between Clarence and I.
Now, if we could just get Cliff to head this way,,,, oh well....................................
wallace
post #24 of 105 Old 01-03-2009, 09:58 PM - Thread Starter
rajdude's Avatar
Sounds good !
I would love to see your setup. Please keep me in the loop about the meet.
I spent the last couple of nights tweaking my G70 to the best of my capabilities.....maybe I should organize a meet.....would anyone be interested?
Originally Posted by wallace1234 View Post
Rajdude,
wallace
-Rajiv
rajdude is offline
post #25 of 105 Old 01-09-2009, 12:13 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
Here's my G70VR displaying a resolution pattern, HDMI 1080p24 into a Lumagen VisionHDP conveting to 1080p60 into the G70 via a Moome card.
It doesn't show in the photo, but it actually does faintly differentiate the single pixel wide lines, both vertically and horizontally.
Test pattern generator is a Quantum Data 802BT.
Chad B is online now
post #26 of 105 Old 01-09-2009, 12:36 PM - Thread Starter
rajdude's Avatar
Hi Chad,
It sure looks good, but notice that the horizontal lines pattern (one line on -- one line off) are so "pinkish". If I am not mistaken that points out that the PJ is running out of bandwidth while displaying 1080p/60 Hz.
Can you try 1080p/48 with reduced porches. I know that the Lumagen can do it because I know a friend who does this with his Lumagen + CRT PJ.
That way the image may be even more sharper! (more differenciated)
1080p sure is sharper on my PJ at 48Hz.
-Rajiv
rajdude is offline
post #27 of 105 Old 01-09-2009, 12:40 PM - Thread Starter
rajdude's Avatar
Quick Q, Chad....are your G70's rasters maxed out?
How is the focus in the corners?
Also have you played with the brightness uniformity controls in G70's menu?
When I get time.....I want to play with that control...maybe they will get rid of the brightness dropoff towards the sides and corners of the image (very obvious in your screenshot)
-Rajiv
rajdude is offline
post #28 of 105 Old 01-09-2009, 12:50 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
Thanks Raj! The test pattern actually has color in some of the lines to test chroma resolution. I think that may be what you're seeing. I will take a super close up of the luma only (no color) 1 pixel wide patches so it will be easier to see.
I tried 1080p48, and I was bothered by flicker. I got into the resolution timing adjustments and input what I could from the thread here, but I'm not sure I got the porches changed correctly. I also tried 1080i/72, but it didn't look any better than 1080i/60 to me. I tried 1080i/96, but I'm not sure it really is putting that out as it didn't look any different either (with test patterns anyway). The menu info screen on the G70 keeps saying it's getting 59.8-60 Hz even when I have the Lumagen set to 1080i/72 or 1080i/96. I had gotten my hopes up for 1080p/48 reduced porch, but I just couldn't get it.
post #29 of 105 Old 01-09-2009, 12:56 PM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
Wow four G70's
How are the tubes?
Not bad... consistent with the 3500 hours... maybe R=9 G=7 B=8
I'm going to give one to my neighbor to upgrade the ECP I gave him.
I'll hook up 1080i tonight and get some screenshots. And then I'll try 1080P@48 and 720P@71.928
Clarence is offline
post #30 of 105 Old 01-09-2009, 12:57 PM
Chad B's Avatar
Quoted: 492 Post(s)
Liked: 1179
Yeah, the rasters are totally maxed out.
Focus is good with green, but b and r have some focus problems in the corners even after careful calibration. Some people have said the G70VR lenses are not ideal on small screens... I have an 84" diag screen, so I wonder if the stock lenses would change things.
The pic makes the uniformity look much worse than in real life. I'm not sure what's going on there. I have played with the uniformity adjustments, and at one time had them where I thought it looked more uniform. But the color uniformity especially caused the raster to light up in the corners, and that was ever so slightly visible on a black screen. I turned them off this time around.
Reply CRT Projectors
