SONY G70 : getting into service menu impossible - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-15-2009, 03:10 AM - Thread Starter
djoul's Avatar
Hi
I am not able anymore to get into the setting service menu of my G70.
Enter Enter Up Down Enter do not operate anymore.
I have tried to switch off during 5 minutes (more than) the projector but when I switch on the power, it makes the same thing...
strange....
djoul is offline
post #2 of 4 Old 02-15-2009, 06:31 AM
Chuchuf's Avatar
Make sure that you have "status" turned on on your G70. It's on the top row of your remote.
Terry
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
post #3 of 4 Old 02-15-2009, 07:00 PM
HT_Fan's Avatar
Terry
Terry,
You know I did that several weeks ago and I muddled through the menus to get this resolved.
I thought I had screwed up my G70 for good but I can vouch for Terry's recommendation on this one.
Tom
HT_Fan is offline
post #4 of 4 Old 02-16-2009, 02:00 AM - Thread Starter
djoul's Avatar
Thanks, it was that... I must be tired....
djoul is offline
Reply CRT Projectors
