Barco Cine 9 with 1400hrs... Too much? - AVS Forum
post #1 of 7 Old 07-06-2010, 07:38 AM - Thread Starter
century_cinema's Avatar
I want to buy a Barco Cine 9 and it was offered to buy one with 1400hrs.
How many hours does it make? Is this too much?
century_cinema is offline
post #2 of 7 Old 07-06-2010, 07:49 AM
nashou66's Avatar
Liked: 52
That is very low hours, only if the drove the tubes hard then it might be
in the mid range. CRT's can last over 10000 hours and the chassis can go even higher.
Whats the price?
And ask for a picture of the tubes.
Athanasios
nashou66 is offline
post #3 of 7 Old 07-06-2010, 10:37 AM - Thread Starter
The tubes are perfect.
Now i need to know what video procssor should i use for VHS; Laserdisc and HD Sources like Blu Ray?!
I was thinking on Lumagen Radiance
post #4 of 7 Old 07-18-2010, 01:27 PM
Vic C's Avatar
Ues a DVDO processor from Anchor Bay. Any of their processors will be awesome on that projector.
If you can find a used HD+ youll be really happy.....Lumegens are nice but I prefer Anchor Bay. I think they make a better product.
Vic C is offline
post #5 of 7 Old 07-23-2010, 04:06 AM
newbieDAN's Avatar
You'll at least need a VP50 in the DVDO product range.
sorting the fly SH!T from the pepper
Now Barco Graphics 1209s (colour filtered) in the house, feeding the mighty beast thru DVDO VP50 & PC-3000 with Moome
newbieDAN is offline
post #6 of 7 Old 07-23-2010, 04:43 AM
Gordon Fraser's Avatar
Liked: 25
Radiance.....all the way
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is online now
post #7 of 7 Old 07-23-2010, 06:50 AM
Citation4444's Avatar
Liked: 27
When I had my Cine9's, I found the Radiance to be a godsend. The ability to correct grayscale, and especially gamma, on these projectors was essential. Very, very difficult to get grayscale right using only the projector's controls and gamma improvement almost impossible. My projectors didn't need the advanced CMS functions as the primaries and secondaries were virtually perfect as long as grayscale was corrected. The Radiance made it quite easy to get perfect grayscale and gamma.
Citation4444 is offline
Reply CRT Projectors
User Tag List
