Can this be salvaged? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-19-2010, 06:08 PM - Thread Starter
bearcat22's Avatar
I've got a salvaged color TV from the trash.
Toshiba model CF27H20.
No remote control, I do have a PDF of the user's manual.
Power comes on, and I'm able to hook up a DVD player so that you can hear sound, but there is no picture coming through.
It does display words on-screen from the menu, but no images are seeming to transmit from the connected DVD player, just sound.
Is there any safe and easy way to test to see if the picture tube is dead?
bearcat22 is offline
post #2 of 9 Old 10-19-2010, 06:12 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 105
Wrong section but the tube is not dead if you see text from the menu.
Might be a bad input board. Maybe a loose connection or solder joint inside or bad capacitor some where
nashou66 is offline
post #3 of 9 Old 10-19-2010, 06:28 PM - Thread Starter
bearcat22's Avatar
Thanks. Hopefully a Mod will move the query where it belongs. Meanwhile, any advice on how to determine what's wrong?
post #4 of 9 Old 10-19-2010, 08:21 PM
draganm's Avatar
Quoted: 21 Post(s)
depends. are you and electronics technician or was your dad a TV repairman?
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #5 of 9 Old 10-24-2010, 04:20 AM
EJ
EJ's Avatar
Have you tried inputs other than the one the DVD player is connected to?
Former USSB uplink operator.
EJ is offline
post #6 of 9 Old 10-24-2010, 11:58 AM
krazyjosh5's Avatar
Careful if you're pulling it apart. There are huge capacitors in there that, even after 20 years, can hold on to a fatal charge. Bring to a technician.
krazyjosh5 is offline
post #7 of 9 Old 10-25-2010, 07:20 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
As long as he doesn't bring it to you.
The above statement is complete BS. The only thing that holds any kind of charge is the picture tube itself.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #8 of 9 Old 10-25-2010, 07:35 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Curt so its still possible to get A shock off A Tube when its not even running
What about A CRT Projection tube like a Lug or P16?
if by chance you touched the pins on the neck could it shock you after A day or so
Cheers..
cinema mad is offline
post #9 of 9 Old 10-25-2010, 08:54 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
A CRT tube acts like a capacitor, and a large direct view TV, say 25" and larger will indeed store electricity, even when discharged. WIth the larger tubes, I have gotten zapped when handling the raw CRT tube, but it all has to do with tube surface area.
Small CRT FP tubes will store a charge as well, but you'll never feel it (at least I don't), when handling them.
The one exception is if you're playing in the HV area of a CRT projector that has just been turned off. Then I always discharge the red HV lead to the chassis, and do it again 2-3 minutes later to be safe.
Back to the FP TV: If you're not playing with the HV area of the set, then the chassis itself is safe to touch within a minute of unplugging it, and the chassis does not store 'fatal' voltages for 20 years. Josh is indeed 'Krazy'
Reply CRT Projectors
