G90 DVI input question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-25-2010, 10:39 AM - Thread Starter
RKS
RKS's Avatar
A few years back I purchased a DVI Input board for my G90 that was mentioned here (I think Palme or something like that) and it's been working beautifully for my older HD unit.
I've finally gotten a bluray system setup on the g90 along with a newer HD Sat unit and was trying to view it at 1080P instead of 1080i. And two things came up, first I'm not converged for it yet, and I can get that fixed but the other is that it's not far off but I see a lot of green snow on the output.
So a few questions, is that also due to the convergence? Or is this just too high a rate for that run of the DVI boards? I see now there's an HDMI board available will I need to upgrade to that?
thanks,
-R
RKS is offline
post #2 of 6 Old 10-25-2010, 12:56 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
I bet you need a better cable. how long is the distance from source to the Input card?
Athanasios
nashou66 is offline
post #3 of 6 Old 10-25-2010, 05:22 PM - Thread Starter
RKS
RKS's Avatar
Athanasios
probably close to 30 feet, but it's a pretty highquality cable I've got in already.
RKS is offline
post #4 of 6 Old 10-25-2010, 06:09 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
if you can bring the Blu Ray player close to the PJ and run a short cable just to test it.
30 feet is kinda long.
Athanasios
nashou66 is offline
post #5 of 6 Old 10-25-2010, 09:24 PM
KrisRoberts's Avatar
My cable run is 35 feet and I have seen green sparkles with my G90 at 1080p that are not present at lower resolutions. Indeed, using a shorter cable to test showed no sparkles. For me, cables from Blue Jeans Cable have worked very well.
KrisRoberts is offline
post #6 of 6 Old 10-26-2010, 01:30 PM
draganm's Avatar
Quoted: 21 Post(s)
thanks,
-R
no you don't need to but the new card is vastly superior. Gamma boost, 12 bit processing, HDMI 1.3 color space, etc.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
