G70 New or old ROM Vers. ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-25-2010, 11:58 PM - Thread Starter
didaschi's Avatar
Hi,
I can buy a Sony G70. I asked for the ROM Vers. and the seller told me this:
H: 1.00 U1: 1.03 U2: 1.04 U3: 1.00
Is it the old version so that I can setup G2?
If I buy a G70 with latest ROM Vers. and I can`t setup G2 what do I have to do to make a good b/w balance? Is there a manual for b/w balance available?
best regards
didaschi
didaschi is offline
post #2 of 9 Old 10-26-2010, 04:38 PM
AFryia's Avatar
You should be able to get good grayscale tracking without adjusting G2.
IMO the geometry is more stable with the newer firmware, I have both.
AJF
No such thing as a stupid question! Well have you got a minute ?
AFryia is offline
post #3 of 9 Old 10-27-2010, 12:53 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Hi AFryia,
Just wondering what Probe you where using in the GrayScale example above
as it looks pretty good, or is that with A VPs CMS..
Also how many hours are on your G70 tubes?..
Cheers...
cinema mad is offline
post #4 of 9 Old 10-27-2010, 06:48 AM
barcoed's Avatar
Personally I would not use a G70 unless I could use the old firmware. I must turn off the Auto black thigy to remove those horrifically bright bowed lines at the top of the tube. Switch off auto black and adjust the G2 - job done and no lines.
If all I could get was a G70 with new firmware, then I'd sell it and buy a digital!
barcoed is offline
post #5 of 9 Old 10-27-2010, 05:17 PM
AFryia's Avatar
Originally Posted by cinema mad View Post
Hi AFryia,
Cheers...
The probe is the HCFR Colormeter (DIY).
No processing or color management for that graph; just the HTPC direct to the PJ. The key is to keep the contrast down. This way your contrast ratio will be higher, gamma will be closer to 2.2-2.5. Down side is overall brightness is lower. Ideally you need a 100% light controlled room.
I run AGB=ON and have to look real hard to see the AGB line. The AGB line resides at the top of the 4:3 raster and I project wide screen only 16:9 etc. The only time I notice it is when I'm half way through a calibration and the contrast, grayscale and gamma are not set.
Tubes were ~2500-3000hrs. With the lower contrast the tubes are still 8&9s.
AJF
AFryia is offline
post #6 of 9 Old 10-28-2010, 09:17 PM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Thanks for your reply AFryia,
My G70 Contrast's @ 55 at this time but run a little 16x9 92" 1.3gain screen in a Bat cave..
I also run AGB on & rarely notice the line myself , and like my Gamma around 2.35..
I've read A couple good things posted about the HCFR DIY Probe..
Thanks again,
Jase...
post #7 of 9 Old 10-29-2010, 04:10 PM
AFryia's Avatar
The same here other than contrast @ 60-65
IMO better than my SpiderII especially at low IRE. More acurate also.
AJF
AFryia is offline
post #8 of 9 Old 11-09-2010, 08:57 PM
Axatax's Avatar
FWIW,
My G70 started life with the new FW and I swapped in a new Y* board set with no ill effects.
Jeff
Axatax is offline
post #9 of 9 Old 11-13-2010, 11:41 AM
AFryia's Avatar
I don't know if it is necessary but I would (did) swap the three matching Y boards just to be safe.
AJF
AFryia is offline
Reply CRT Projectors
