Sony CRT, wont power, 4 blinks what does it mean? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-21-2010, 05:33 PM - Thread Starter
Ladic's Avatar
Quoted: 29 Post(s)
I have an older SOny KV-32FS16 crt tv, a while ago i kept turning off by itself, now it wont even turn on, if you hit power it makes a weird sound kinda like birds chirping.
However it gets 4 blinking red lights at the stand by light.
I found this online:
http://www.techlore.com/article/1544...linking-Codes/
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
dont understand that mumbojumbo, does it mean my tv is caput?
Ladic is offline
post #2 of 4 Old 11-22-2010, 10:04 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
Yes, it has a problem in it. If you don't understand the quote above, then please call a tech, as you're liable to get zapped since you're not a technician.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 4 Old 11-22-2010, 10:33 AM
Reddig's Avatar
Quoted: 213 Post(s)
Liked: 410
Yes it is caput. I would call a Sony technician or just dump it and get ya a new set.
JBL Pro Cinema-JTR Subs
MANCHESTER UNITED!!
Reddig is offline
post #4 of 4 Old 11-22-2010, 11:57 AM
secstate's Avatar
You could probably replace your for free on CL. Only a *very* few direct view CRTs have any value anymore. As others have said it points to failed components if you don't know what it means you aren't going to be able to fix it. That said hit your local CLs for a free or nearly so CRT or throw in the bag and go digital.
secstate is offline
Reply CRT Projectors
