help me please: MARQUEE and 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-05-2011, 03:30 AM - Thread Starter
cencio's Avatar
My chain has now some new components.
Two HD/3D sources : SKY HD/3D SATELLITE RECEIVER and OPPO BDP 3D 95.
All the sources come into the Lumagen XS 3D+.
The Lumagen output goes into the nw Lumagen CRT 3D DRIVER BOX (that is connected to a IR 3D GLASSES EMITTER)and this output goes into the MOOME VIM MP FULL HD V3 on the Marquee.
The Lumagen 3D configuration are AUTO1,2 for 3D output for both the sources-
The results are in these images:
FOR THE OPPO
FOR THE SKY HD RECEIVER
Can anyone help me to understand what and where is the problem?
Is the Moome card enabled to receive this input?
Vincenzo
Vincenzo
One of the most essential things of the life is to speak in the right moment and when you have important things to tell.
Otherwise you have lost an opportunity to keep silent
cencio is offline
post #2 of 9 Old 06-05-2011, 07:32 AM
napos's Avatar
Vincenzo,
I believe that for a Blu Ray 3D you need the new Moome external box that is HDMI 1.4 compatible. Sky HD 3D is using an HDMI 1.3 format, so your 3D box should work with that, but check the specs and see if it supports satellite 3D side by side mode.
Nicholas
I love my Sky HD!!!
napos is offline
post #3 of 9 Old 06-05-2011, 09:33 AM - Thread Starter
cencio's Avatar
Originally Posted by napos View Post
Vincenzo,
I believe that for a Blu Ray 3D you need the new Moome external box that is HDMI 1.4 compatible. .....
Nicholas
Nicholas,
I think so.
Vincenzo
cencio is offline
post #4 of 9 Old 06-06-2011, 06:38 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Im pretty sure that the Lumagen 3D will Pass 3D into the Moome full HD HDMI1.3 internal card As I believe this was the whole point for Lumagen to introduce 3D compatibility for CRT... I think this is the same config Craig (CIR) is running with his G90 as well as others members with good results..
I hope Craig Doesn't mined here is his 3D video chain: The signal chain is simple: Oppo BDP-93 > Lumagen RadianceXE+3D > Moome FULLHD Sony IFB. You also need the Lumagen CRT dongle to send the TTL timing to the 3D glasses IR emitter, and you need the IR emitter and glasses.
Refresh rates include 96Hz for film material (24/48Hz) and 120Hz for video based material.""
I think its A setting in the Lumagen XS 3D or the Lumagen CRT 3D DRIVER BOX as your
screen shot shows no V Sync..
Go here and talk directly with the guys that are running the same configuration..
http://www.curtpalme.com/forum/viewt...49c8ea5370aaab
Cheers...
cinema mad is offline
post #5 of 9 Old 09-26-2011, 01:22 PM
thewolfman's Avatar
Quoted: 37 Post(s)
Hello!
I bought a Electrohome 9500lc with a Moomi 1,3 in it and wonder if the new
3DFury are as good as Lumagen XS3D? I payed 1700$ for PJ and dont want to pay more then like 500$ for 3D..
I intend to use PowerDVD 11 with 3D graphics card on my computer. Will that work?
I could, if it makes a difference, spend a little more on a better 3D graphics card..
Is there a chance I can run 1080i 120hz with 3DFury?
Regards
Thewolfman
Sweden
thewolfman is offline
post #6 of 9 Old 09-28-2011, 01:50 PM
CIR-Engineering's Avatar
Originally Posted by cencio View Post
M
WRONG.
I have posted this info in many threads already. You cannot use auto mode for 3D on CRT as you must specify an output resolution and timing as well as specifying frame sequential.
craigr
Precision Video Calibration Craig Rounds
JETI Specbos 1211 Spectroradiometer
Klein K10-A Laboratory Grade Colorimeter
Murideo Fresco Six-G & Six-A HDMI 2.x Multimedia Generator / Analyzer
LightSpace XPS Pro & ChromaPure Pro Color Calibration Software
www.CIR-Engineering.com - craigr@cir-engineering.com
CIR-Engineering is offline
post #7 of 9 Old 09-28-2011, 07:33 PM
overclkr's Avatar
Liked: 66
Originally Posted by CIR-Engineering View Post
WRONG.
craigr
Go get em' Craig!
overclkr is offline
post #8 of 9 Old 09-30-2011, 07:28 AM - Thread Starter
cencio's Avatar
WRONG.
craigr
Please Craig,
you have a PM.
When you will have a few time read it.
Best Regards.
Vincenzo
cencio is offline
post #9 of 9 Old 10-09-2011, 05:03 PM
Please Craig,
you have a PM.
Best Regards.
Sure, I am just supper swamped right now. I will have a little free time in about one week from now and should be able to help.
I just did a Marquee 9500LC Ultra 3D stack a few weeks ago so I know you will wind up in good shape once you get it figured out You have the correct hardware.
craigr
Reply CRT Projectors
