Marquee 9500LC Vertical Stripes issue.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-25-2011, 08:53 AM - Thread Starter
klancelot's Avatar
Hi all..
I have Two Marquee 9500LC.
Each Board Version is CLM V3.4 / DPB D4.8 / HDM 08P Ver / VIM 03P Ver.
All Board Socket and Connector is cleaned.
This picture is 1920*1080p mode.
Please help.
klancelot is offline
post #2 of 3 Old 06-25-2011, 05:36 PM
Tim in Phoenix's Avatar
Hello
That is ringing, could be the HDM or maybe you should try DPB5.20 as usually found with v3.4 E.mail me with your address I will send you a 5.20 chip.
Tim
Tim at E-Tech ooo ehometech@earthlink.net ......your Marquee Pro Shop!
Tim in Phoenix is offline
post #3 of 3 Old 06-25-2011, 10:52 PM
draganm's Avatar
Quoted: 21 Post(s)
also, the wire leads to the rear heat sink, 3 boards with 3 leads each = 9 wires should not be braided together. On some late model VDC replacement tubes with yokes they braided these wires together like a Pony-tail. Noise from the stig amplifier will cause vertical jail-bars like those pictured.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
