reposted proper forum rear projection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-28-2011, 06:56 PM - Thread Starter
Roxdog's Avatar
Rear
Roxdog is offline
post #2 of 3 Old 06-29-2011, 07:29 AM
Curt Palme's Avatar
Quoted: 33 Post(s)
Liked: 61
Wrong forum, but I'll answer.
No, the cooling fluid has nothing to do with the set shutting off. My guess is that the STK chips were going bad, and causing the set to shut down. By getting into the unit, you disturbed the chips and they failed completely. I'll bet everything will be fine when you change the chips.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 3 Old 06-29-2011, 01:54 PM - Thread Starter
Roxdog's Avatar
thanks stk's and pico's it is then
Roxdog is offline
Reply CRT Projectors
