Toshiba TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-15-2011, 12:06 PM - Thread Starter
Diadon232's Avatar
Some time ago there was discussion about a solid, horizontal white line appearing on Toshiba TVs. Other than possible CRT damage is there any chance of electrical fires? Answer received - Thanks
Diadon232 is offline
post #2 of 4 Old 07-15-2011, 01:45 PM
P719C1's Avatar
You mean vertical collapse (vertical deflection failure) like on this TV?
Fire is unlikely, I've never heard of any fire caused by vertical collapse. But I suppose it is possible if the loose electrical joint causing the problem experiences a lot of arcing and there are enough combustibles around. A lot of later-model CRT TVs will cut off the picture completely when vertical collapse occurs so as to avoid burn-in, but then that makes it a bit harder to diagnose the problem with the TV. It's also not a Toshiba-specific problem, it can happen with any CRT and is a rather common problem.
By the way, this post would be better suited for the "Direct View (single tube) CRT Displays" category rather than this one.
P719C1 is offline
post #3 of 4 Old 09-10-2012, 09:39 PM
amri's Avatar
what component i need change?
amri is offline
post #4 of 4 Old 09-11-2012, 06:57 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
The one that is defective.
(sorry, couldn't help myself)
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
Reply CRT Projectors
