help please on Barco graphics 808 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-17-2011, 02:24 PM - Thread Starter
v1rtu0s1ty's Avatar
Is it possible to invert the display without having to change some wires? Right now, the projector is on floor and buttons are facing upwards.
And I'm also wondering why I'm not seeing the feed from my bluray.
Any help would be greatly appreciated.
v1rtu0s1ty is offline
post #2 of 8 Old 07-17-2011, 03:06 PM - Thread Starter
v1rtu0s1ty's Avatar
found it, page 27
http://www.curtpalme.com/docs/BarcoG...08_Install.pdf
still wondering though why I was able to diplay my linux at 1920x1080 but the bluray via hdfury doesn't show up. I'll keep troubleshooting ...
post #3 of 8 Old 07-17-2011, 03:40 PM - Thread Starter
v1rtu0s1ty's Avatar
Anyone please, I got it to display but movie will get displayed on for 2-3 seconds and very curvy. Finally, it would turn black. It was not like this when I was using my linux.
I also couldn't bring up the menu anymore.
post #4 of 8 Old 07-20-2011, 11:55 PM - Thread Starter
v1rtu0s1ty's Avatar
This is fixed. I made an HD15 to DB9 cable. HDDVD/Bluray player is now connected on port 3. 1080p doesn't work though but 1080i. I also need to continue reading manual for the convergence.
post #5 of 8 Old 07-26-2011, 07:58 AM - Thread Starter
v1rtu0s1ty's Avatar
I have not done any readings on convergence. LOL. I wasn't satisfied with the setup only outputting 1080i. Glad someone from Curt's forum gave me a diagram on how to negate a signal which I can use on port 4/5 since it supports 1080p. Here is the latest, positve h/v sync signal from hdfury1 negated before it reaches board 4/5 h/v ports.
here it is, version 1
post #6 of 8 Old 07-26-2011, 09:15 AM
modelaratrod's Avatar
I'm going to be looking @ doing something like this once my HD Fury @ shows up, Great work keep us posted.
modelaratrod is offline
post #7 of 8 Old 08-14-2011, 01:05 AM - Thread Starter
v1rtu0s1ty's Avatar
modelaratrod, I built my second version. It's got a casing now.
I updated this post at 2am, August 15. I attached screenshots after learning convergence.
post #8 of 8 Old 08-15-2011, 10:11 PM - Thread Starter
v1rtu0s1ty's Avatar
I posted this earlier at curtpalme.com
I redid the focusing and convergence using binoculars. I'm very pleased with the results.
Reply CRT Projectors
