9500lc and 72hz? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-17-2011, 09:57 PM - Thread Starter
htguy1's Avatar
Hi,
I am running my 9500lc at 60hz but would like to smooth out the motion and am wondering if this would make things look better or not? I have done many mods to this PJ jncluding the VIM opamps etc so it should have better frequency response etc.
God bless...
Mark
htguy1 is offline
post #2 of 4 Old 08-18-2011, 10:35 AM
Tim in Phoenix's Avatar
Hello
I was running 72hz from a pc for years, it looked real good. You need to have 72hz sources, the projector merely runs what you feed it.
Tim at E-Tech ooo ehometech@earthlink.net ......your Marquee Pro Shop!
Tim in Phoenix is offline
post #3 of 4 Old 08-18-2011, 03:28 PM
draganm's Avatar
Quoted: 21 Post(s)
Originally Posted by htguy1 View Post
Hi,
I am running my 9500lc at 60hz but would like to smooth out the motion and am wondering if this would make things look better or not? Mark
yes, the question is will it look $2900. better (cost of Lumagen radiance XS+ ?).
Individual results may vary
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #4 of 4 Old 08-18-2011, 07:41 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Using the radiance to get a perfectly flat greyscale, RGB and Gamma of 2.35 ?
Umm Yes its worth it!!!!
Athanasios
nashou66 is offline
Reply CRT Projectors
