servicing my projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2011, 04:17 AM - Thread Starter
zipstor's Avatar
Hi there,
I have been servicing my Panasonic PT-L757EA today, the 3 lcd displays were marked by humidity and needed to be cleaned. So I removed the motherboard and covers then done the cleaning of every optical component as I was there, then cautiously put everything back together. After refitting the top console, I turn on the power supply and nothing happened, no power at all. Usually the fan goes on straight away. I have serviced a.few.other projectors in the past and the whole operation went fine everytime..No idea of what is happening now. let me know if you have any idea of what can have gone wrong.
Thanks in advance.
zipstor is offline
post #2 of 4 Old 08-28-2011, 12:50 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
You're in the CRT forum. You need to retrace your steps, you've missed a connector or a ribbon cable or something.
Digital projectors are not designed to be serviced, they are completely disposable, and chances are Panasonic will not have a proper service manual for it.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 4 Old 08-30-2011, 02:50 AM - Thread Starter
zipstor's Avatar
The way this machine is designed on the inside, things are clearly in place for easy servicing. But yes thanks for your advice I have no other choice but to do this..
zipstor is offline
post #4 of 4 Old 08-30-2011, 04:40 AM - Thread Starter
zipstor's Avatar
Problem solved. There was a plastic pin behind the cover for the light bulb that needs to be pushed in otherwise the power stays off..
Now the 3 course are out of phase.. I'm reporting in the other section. Thanks again.
zipstor is offline
Reply CRT Projectors
