Thomas Electronics 9M198PT553 CRT/Marquee - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-02-2011, 05:39 PM - Thread Starter
hjhjr's Avatar
I purchased a marque 8500 converted to a 9500LC . The tubes are Thomas Electronics 9M198PT553 CRT. I would like any input as to the quality, operation or any other input that anyone has. It looks like that the orginal 8" yokes were used on the 9"tubes. The DY outer edge by the CRT is about
3/8" from the tube, when it is as far forward that it can go.
Hilton
hjhjr is offline
post #2 of 5 Old 09-02-2011, 09:15 PM
Ericglo's Avatar
Quoted: 1700 Post(s)
Liked: 797
Nash should be able to tell you everything you want to know about those tubes. You can probably get him easier over at Curts.
WHere are you located? There are a couple of CRTers in Lafayette.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #3 of 5 Old 09-03-2011, 09:13 AM
Axatax's Avatar
It looks like that the orginal 8" yokes were used on the 9"tubes. The DY outer edge buy the CRT is about
Why won't it go fully forward? This will never focus properly.
Axatax is offline
post #4 of 5 Old 09-03-2011, 10:58 AM - Thread Starter
hjhjr's Avatar
The inner diameter of the DY yoke is against the tube.
hjhjr is offline
post #5 of 5 Old 09-03-2011, 12:34 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Thats just how it is, the bell housing is a different shape . So the DFY won't fit as nicely as on a LCP or LUG and even on those there is a slight gap. But if you disconnect the focus Yokes and look at the grid, no loosen all the magnetics and slide the focus yoke up and down the tube neck to get the best focus in the center you can. With no power it should still focus ok, if not then your yokes magnetics are not of proper gauss and would need re-calibrating. or you could try to find some other yokes and by testing each one find the best yoke for each tube.
On my test tube I used to modify the VNB's for those tubes I got good results with the 8 inch DFY's the 9's are not much different in Shape, the coils might be slightly different. But otherwise people have had them work fin on other 9 inch tubes.
here is a picture Scott sent me, 8" on left 9 " on right. I think the restores are different but i cant tell from this pic.
Athanasios
nashou66 is offline
Reply CRT Projectors
