Tips on changing out tube in Runco 943 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-07-2011, 03:31 PM - Thread Starter
Darkhand's Avatar
I recently picked up a broken runco/barco 708, and since i am a newbie to CRT PJ's i wanted to know if there are any precautions i should take while taking it apart to see whats wrong with it.
thanks
Darkhand is offline
post #2 of 5 Old 09-08-2011, 09:37 PM
benareeno's Avatar
Quoted: 18 Post(s)
"broken" is not enough info...does it just fail to power up or what are the symptoms of it being broken? How do you know you need to change a tube?
benareeno is offline
post #3 of 5 Old 09-08-2011, 10:05 PM
Axatax's Avatar
If you're not sure what's wrong with it, what makes you suspect a tube? (Not that you're wrong, but tubes issues will not generally stop the PJ from firing up to the point of throwing some type of diagnostic code).
Any error LEDs? Fans? Picture?
Axatax is offline
post #4 of 5 Old 09-08-2011, 10:08 PM
Axatax's Avatar
ED: Double.
Axatax is offline
post #5 of 5 Old 09-09-2011, 06:50 PM - Thread Starter
Darkhand's Avatar
when i got it the red led- hold down EHT was on, found out Red tube is broken in half, took some advice from guys on curtpalme.com and disconnected it and powered up and both green/blue are now working.
I guess i have to find a redtube first before i can change it.
Darkhand is offline
Reply CRT Projectors
