G70 lost settings! - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2011, 04:23 PM - Thread Starter
ilias's Avatar
I used a VP30 to my SONY G70 (HDMI) with 2 different settings, one for TV-DVD with
PIONEER 550 RECORDER, and one for BLUE RAY, but the projector need every week fix the calibration! why this?
ilias is offline
Old 09-13-2011, 04:53 PM
AFryia's Avatar
What is it that needs adjusting exactly?
AJF
No such thing as a stupid question! Well have you got a minute ?
AFryia is offline
Old 09-13-2011, 05:12 PM
lewis's Avatar
Most likely a bad Dallas chip. Do a search and replace. There is a Li ion battery on the chip that has a rough lifespan of 10 years. If your's is original chances are the storage capabilities have disappeared.
lewis is offline
Old 09-15-2011, 12:23 PM - Thread Starter
ilias's Avatar
The 3 colors, and the focus!
ilias is offline
Old 09-15-2011, 12:24 PM - Thread Starter
ilias's Avatar
Is easy to chance this battery? were is that chip?
ilias is offline
Old 09-15-2011, 09:23 PM
lewis's Avatar
The battery is integrated into the chip. Looks like this. On the G90 its on the YA board. Not sure about the G70 but probably the same CPU board. You will need to try to copy the contents of the old chip onto the new using an EEPROM reader/writer, otherwise replace and do a setup from scratch.
http://www.ebay.com/itm/Dallas-Chip-...-/120598151457
lewis is offline
Old 09-16-2011, 12:30 AM
Axatax's Avatar
If he's losing settings, there's probably nothing to copy at this point, but yeah, ^ this procedure is on the mark.
Axatax is offline
Old 09-16-2011, 05:38 AM - Thread Starter
ilias's Avatar
Thank you all!
ilias is offline
