Sony D50HTU adjustment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2011, 09:08 AM - Thread Starter
ericgarvin's Avatar
I am having a little problem with my blue crt on my sony d50htu. I pulled the projector out of storage and I am setting it up again. I have the original remote and manuals. During the setup the blue crt was the last to dial in. Green and red alligned without issue. The blue test pattern is not completely showing up on the phosper face. One side of the hatch is completely off the edge and cannot be seen. I looked at the tube face with sunglasses on to verify the problem. The lenses are hd145 delta's. Any help would be appreciated.
ericgarvin is offline
post #2 of 5 Old 10-02-2011, 02:59 PM
Vic C's Avatar
not sure if those have a width coil that control the master width or not. I had an old 1031 that had to be tweeked to get the width right. I think my Dwin had width coils but I never had to mess with them....
Did you reset the projector from scratch when you pulled it out of the closet? Mabe its still set up from a previous settings that you should delete and start again.
Vic C is offline
post #3 of 5 Old 10-02-2011, 04:10 PM - Thread Starter
ericgarvin's Avatar
Thanks for the reply, I don't believe I need to actually adjust the magnets on the yoke. I believe it is either a blanking issue or more simply a misalignment on the initial CRT conversion angle. Tied together with the centering on initial setup.
post #4 of 5 Old 10-11-2011, 07:17 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Well hey Eric, since you apparently have all the answers, why post looking for assistance? Vic happens to know his stuff, but apparently you know better.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #5 of 5 Old 10-22-2011, 09:43 AM
raster's Avatar
Be nice curt!!
raster is offline
Reply CRT Projectors
