Has anybody get the Marquee 8500/9500 doing 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-14-2011, 10:27 AM - Thread Starter
richmond5's Avatar
Quoted: 20 Post(s)
Hi:
I have Marquee 8500 hookup with DVDO edge and Moome ext HDMI 1.4. Playing with OPPO 95, cannot get any image at all. Is the setup possible for 3d?
richmond5 is offline
post #2 of 3 Old 10-17-2011, 12:48 PM
noos@xp37's Avatar
Well, take the Edge out of the video chain or make shure he passes the signal without touching (pass through). The Edge can only handle standard refresh rates like 50/60hz, and 3D is mostly 100hz or 120hz. So go directly from the lumagen EXT3d into the Marquee - but you will have ghosting because you can not add porches and or blank lines to give the green tube time to decay. But probably you have P43 phosphor in your Marquee. What is the serial number of your Marquee, and or what is the number on your green tube? If you have P43, that is very good for 3D, but not all can live with it in 2D.
Best regards from Munich
Marc
noos@xp37 is offline
post #3 of 3 Old 10-18-2011, 05:20 AM
cencio's Avatar
Originally Posted by richmond5 View Post
Hi:
You have to control the dip switch on the Moome EXT 1.4.
Please, follow the user manual of the EXT for the RGBHV/CRT input.
I hope you need this help.
Vincenzo
One of the most essential things of the life is to speak in the right moment and when you have important things to tell.
Otherwise you have lost an opportunity to keep silent
cencio is offline
Reply CRT Projectors
