fix a fuzzy Sony 7220 Crt - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-21-2011, 10:34 PM - Thread Starter
binkey's Avatar
I have a Sony 6' Projection I bought brand new 25 years ago it worked great but when it stoped dead I took it to be repaired and was told it needed a power transformer board ( not true I discoverd) after it's return it was never as sharp as before ! I'm sure he screwed something up somehow.
It does get a little better after an hour or so but not as great as it was.
Does anybody have copies of the service manual so I can tell what does what under the hood ?
Thanks for any help with this.....
binkey is offline
post #2 of 2 Old 10-28-2011, 10:49 AM
geisemann's Avatar
On those old models you have to adjust the focus block and the G2 after the transformer is replaced
The tech was just lazy
Greg
www.eisemann-theater.com
Gregory C. Eisemann Senior Electrical Engineer, Satcom Engineer, Opnet Engineer, Network Engineering, Satellite Engineering
geisemann is offline
Reply CRT Projectors
