Barco 1208/2 goes partial dark after a period of run time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-22-2011, 09:06 AM - Thread Starter
underdog57's Avatar
What to look at to find the problem ?.
I had it happen the first time after about an hour play, the next day it was ok , till about 20 minutes .
It was dark on the right side of the picture . like 3/4's of it .
I went in the service menu and the green menu is dark also ...
Its ceiling mounted ...
I had the picture fairly close to the edge of the crt's , would drift in the electronics push that too close ? . I'll wait and listen to you guys now !
Thanks in advance ..
I do have a working worn tube parts projector , so should be able to swap boards easily ...
keep at it , results are worth it !!
underdog57 is offline
post #2 of 3 Old 10-24-2011, 08:33 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Check the 17.5 volt test point on the SMPS and adjust if it's off. I'll bet it is.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 3 Old 10-24-2011, 07:08 PM - Thread Starter
underdog57's Avatar
Thanks Curt !
I should of waited for your reply , just popped out three boards to get out the one we (my dad ) thought might have weak capacitor(s) in ...
I think i'm going to have a problem hooking back a connector or so ...
Not as easy as I thought , and its hanging a tad high ...
Will look at getting them back in tommorrow and look at your suggestion ...
Thanks again
Bob
Reply CRT Projectors
