help with marquee 8500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-03-2011, 06:58 AM - Thread Starter
la_giobba's Avatar
I had a problem of "vsync out of range" with a marquee 8500. I changed the VIM and I solved this problem. But now a strange thing happened: a part of pic what is supposed to be in the bottom is upside (see sample pic). What is happened?
la_giobba is offline
post #2 of 4 Old 11-03-2011, 09:53 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Check your 'phase' control setting. It might be at 0 or 100, factory default is 50.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 4 Old 11-03-2011, 11:54 AM - Thread Starter
la_giobba's Avatar
Thanks, I tried with "phase" but it seemed not very useful.
I will try again but, by the way, other suggestion?
post #4 of 4 Old 11-03-2011, 05:13 PM
draganm's Avatar
Quoted: 21 Post(s)
what does that mean? Does the Phase control affect the picture or not?
If it does, at which value is the pic closest to "correct"?
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
