an not get 1080i working on my Vidikron VPF50HD (ECP 4500) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-06-2011, 02:05 AM - Thread Starter
ericfx1984's Avatar
I have this posted on Curt Palme's forum... this is kinda a short version of that thread
I am hoping you guys have some ideas on the settings...
it shows multiple images if I do... like several of the same images stacked, as in 2, 3 or 4 matching images on the same screen
curt said to try a T for the H and V input on the 5 pin bnc... I did that
I actually got it to lock once... then the software reset the screen resolution
I must have the settings wrong...
ideas?
ericfx1984 is offline
post #2 of 2 Old 11-07-2011, 08:53 AM - Thread Starter
ericfx1984's Avatar
any ideas?
Reply CRT Projectors
