Nec pg6+ - AVS Forum
post #1 of 3 Old 03-12-2012, 11:34 AM - Thread Starter
ge601's Avatar
I recently got a NEC 6 PG +, I turn it on, show 00 status (which means no error, right?)
But none of the tube come on, what do I need to check next?
Sorry, this is my first time have a CRT projector, so might need to ask a lot of questions here.
Thank you all in advance.
ge601 is offline
post #2 of 3 Old 03-12-2012, 02:55 PM
Curt Palme's Avatar
Do you have the remote? The set is pretty useless without it. If you have the remote, put up a test pattern. If you get the test patterns, then you just need to send it a signal. The PG+ may or may not have a video/Svideo board in it. Feed it a signal from a laptop or PC via the RGB inputs. If you don't get an image, then you either have a bad deflection board or video output board that is killing the picture to the tubes. Feel free to email me through my site below for further troubleshooting.
Cheers!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 3 Old 03-12-2012, 04:02 PM - Thread Starter
ge601's Avatar
Yes, it come with the full function remote and metal kit to hang it upside down.
When I push the button on the remote, I can see the light blinking indicating it is receving the signal.
I did hook up a laptop using RGBHV cable from vga output.
Currently no tube will come on (I looked through the lens)
I will post on your web forum too, thanks for your help.
What is the correct key sequence to put up a test pattern? I did read thrugh the install manual once, but can not figure out when I see nothing coming out of the tube.
Cheers!
ge601 is offline
Reply CRT Projectors
User Tag List
