up and running - AVS Forum | Home Theater Discussions And Reviews
Old 03-29-2012, 12:42 PM - Thread Starter
mutt1's Avatar
right got my seleco 150 running old bit of kit, I know picture is good but in black and white
mutt1 is offline
Old 03-29-2012, 02:56 PM
draganm's Avatar
Quoted: 21 Post(s)
nothing wrong with that, gotta start somewhere. CRT is actually one fo the best ways to watch B&W movies.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Old 03-29-2012, 03:02 PM - Thread Starter
mutt1's Avatar
but its ment to be in colour right
mutt1 is offline
Old 03-29-2012, 10:16 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Are you sure your not using the wrong output form the DVD player? possibly only one of the three component outs?
One thing you need to get into the habit of, list your equipment model numbers and how it is all hooked up or as its called the video chain.
Athanasios
nashou66 is offline
Old 04-03-2012, 06:17 PM
Vic C's Avatar
More then likely you have a composite video cable going into the Green input for component video. But the image wouldnt be a perfect B&W it would still look very grainy. at least you know its getting a signal.
Vic C is offline
