Hey, thought some old time CRT guys might be able to point me in the right direction. We have an old Umatic VO-2600 that is not responding to any input on the buttons. Have not been able to find any repair stuff online or in the forums. Can anyone point me in the right direction or move this to the best forum area?
Oh Tim, if only I did not have to convert these stacks of 3/4inch tapes to digital.
Wow..I used to repair those, but that was a very long time ago as Tim pointed out. So of course, there's no way I would remember what could possible to the problem.
Hey, just came up with a potential solution while relaxing and looking at the schematics. Underneath the main chassis is the main power supply board. The board contains several fuses on it. If one or more fuses were to go out, would the entire machine likely refuse to power as a whole or would it just lose certain functions? (i.e. like a car stereo fuse)
It does neither. When the elevator is plopped down (just to clarify, this is a top loader) the machine does not respond at all. All belts look okay, but I have spares so can do if need be. I've checked the switches to see if something might trigger the onboard Logic controls but there is no response.
The following is part of an email and pictures I sent to VideoLabGuy yesterday describing the situation. The pictures show the deck without the cassette loader:
Which sensor bulb are you talking about? Is it the pilot light that stays on the whole time? Last time that went out, the "STANDBY" light stayed on until I replaced it and then everything was okay. I changed it with a spare this time too, but to no avail. There is no "STANDBY" light at all. I also tried pressing down the two cassette sensor prongs that connect to the AC Motor switch. These do not respond in stopping the main motor.
The cassette-up switch at the front also does not respond. This is circled in red in the picture labled "umatic2". Not sure if these could get things going again, but felt I should mention. As far as I know, all belts seem to be functioning. The whole things rotates like clockwork underneath!
If it is not too much trouble, could you circle any the sensors or points to check within the top level mechanisms in the attached pictures? I've included a couple without the elevator on. If a schematic or blow out diagram would be better, let me know and will scan one in too.
If it helps, the machine had a cold start after sitting dormant in my basement for a couple months. It played a tape fine for a few seconds until I tried to eject it. Now even the eject button does not produce a response. Do you think a bad fuse or cap is at all likely? I came across the power supply board at the bottom and noticed several of these, but did not think to check them at the time. One guy on the AVS forum said it would be unlikely for the entire machine to power up if it was a bad fuse, but felt I should ask anyhow.
Originally Posted by UncleWill /forum/post/22095065
Mike,
If my memory serves me right, once the tape drops, the carousel should automatically pull the tape out of the cartridge and around the rotating video head assembly.
With what you have mentioned, that's the lesser problem. the real problem is the tape being fully loaded around the rotating head assembly, with no response (no play, rew, ff, etc) from the front panel.
So, there should only be a few things that would prevent auto-load (full tape out of the cartridge and around the rotating video heads assembly).
Two things to check, one is a lamp....Ok, I just read where you had replaced a sensor lamp. Was the replacement an original. Because not any lamp will make this circuit work.
Also, and since the unit has been sitting for a long time, I would suspect one of the contact switches being oxidized or not making a good closed contact. You would need a few very small clip-leads to check this out. And once you're able to get your hands on them, you'll need to connect them on each of the switches-one-at-time, and complete the contact yourself once the tape drops.
Mike, are you still there? I have never really gone in depth on one of these things before but actually having someone walk me through it in person would be an honor. I do understand what you mean about fiddling with the contact switches but going from here may require a bit more of a learning curve. PM me if you can. Thanks!
I used to be really good with those U matics, but has since moved on to Betacam. I still have a Betacam SP deck, and several Pro cameras. I thought about getting back into repairing the Betacam units because there's not many repair facilities that still do them, but with my hands also being filled with going forward on some other things, I'll not likely go back into doing these decks and cameras.
Have you solved your dead U-matic problem yet? I have a great deal of experience with those machines. I have a number of pointed questions to ask but I will not waist my time typing them if the problem is solved. Write me at doogie812@yahoo.com
Hi i am new to this forum and i saw you guys know about the old u matics i mainly stick around the NBTV forum but need some advice on 2 u matic machines i have the main one i would really like to get going again is the sony vp-7040.
It worked fine for some time but now when i switch it on i can hear a relay switch come on and the play button light comes on for a short time then just the stand by light stays on and eject play so on buttons do nothing when pressed any advice would be great .post to either http://www.youtube.com/user/039dalekmoore2007
My email is dalekmoore2007@gmail.com or here i might start another thread
Trying to track down a copy of the Sony VO-2600 service manual. If anyone has one, I'd be grateful!
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
