Will tubes light? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-21-2012, 04:43 PM - Thread Starter
ilpostini2's Avatar
Quoted: 55 Post(s)
Liked: 25
I just picked up a 6pg for $50, comes with no remote .
Should the tubes light when plugged in or do I have to have a source plugged into it?
ilpostini2 is offline
post #2 of 7 Old 06-22-2012, 05:19 AM
jjoboh's Avatar
you will need a source ,and definately a remote to set it up
jjoboh is offline
post #3 of 7 Old 06-22-2012, 05:22 AM - Thread Starter
ilpostini2's Avatar
Quoted: 55 Post(s)
Liked: 25
That's the answer I was hoping for
post #4 of 7 Old 06-22-2012, 05:24 AM
jjoboh's Avatar
if the signal has not been registered you will need the service remote not the small remote
to enter the signal and do other setup
jjoboh is offline
post #5 of 7 Old 06-23-2012, 07:49 AM
stefuel's Avatar
Quoted: 40 Post(s)
Liked: 26
Where in Marshfield are you? I think there is two people in Marshfield with the remote you need.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #6 of 7 Old 06-23-2012, 12:05 PM
jtnfoley's Avatar
NEC Setup remotes are tough to clone to universal remotes, IIRC, because the setup remote has a 'shift' key that is extensively used during the setup procedure.
I have a setup remote you can borrow until you can source one. Curts' site has PC control software and a cable pinout.
Heck, I may even still have my NEC cable for the software if you want to run it on a laptop or convenient desktop: http://www.curtpalme.com/NECPG_PCControl.shtm
I enjoy mowing my lawn. It's the only two hours of my week where I know what's expected, understand the job, can forsee completion, and look back and see progress.
jtnfoley is offline
post #7 of 7 Old 06-25-2012, 11:04 AM - Thread Starter
ilpostini2's Avatar
Quoted: 55 Post(s)
Liked: 25
I'm in the Blackmount section.
Reply CRT Projectors
