Sony G70 720P 50hz Image too narrow cannot fill up the screen. - AVS Forum | Home Theater Discussions And Reviews
Old 07-01-2012, 06:13 PM - Thread Starter
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi All,
I have been using 1080p 60 hz without any issue.
Now try my local Set top with 720p 50hz unable to fill up the screen. Only half of the screen. May I know how can I fill up the screeen.
Remember in the pass when I use RGB without issue. My set up as follows:-
TV set-top HDMI - Onkyo 886 Pre/Pro - HDMI to Sony G70 with Moome V2 card.
Marcus Gan
Marcus Gan is offline
Old 07-01-2012, 08:13 PM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
For 720p@50 You need either an external VP/Scaler or pc that can allow you to reduce the porchs that will then allow full Raster width..
Unfortunately thats always been the case with the standard 720p-50 timing..
Cheers..
cinema mad is offline
Old 07-01-2012, 08:41 PM - Thread Starter
Marcus Gan's Avatar
Quoted: 12 Post(s)
Hi, cinema mad,
thanks.
Marcus
